Re: Gen 3 Hemi front cover and accessories
[Re: biff426]
#1658891
08/14/14 02:31 PM
08/14/14 02:31 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
your setup is much different than mine but I bought a SFI, I think TCI balancer for my hemi and couldn't use it without changing how I already had my alternator mounted. The new balancer did not stick out nearly as far as the stock one I'm using so it sits on a shelf now.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: biff426]
#1658893
08/15/14 09:03 PM
08/15/14 09:03 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
There are different hubs for ATI dampers, with different depths. That will make alot of difference to how things line up. http://www.atiracing.com/products/dampers/charts/damchrysler.htmMy set up is still early in layout, but I have a motor plate and remote electric water pump. With a ATI damper with no serp. pulley (smooth shell)with a ATI drive mandrel for pulleys. I am using a 5.7 truck cover also but cut all the mounting stuff off it. Sorry I can't give you a combo for what you have. But if you are using a truck cover I think you would want all truck pulleys/drive parts.
"Just a Bracket car dressed up like a streetcar"
[Re: biff426]
#1658895
08/20/14 02:32 AM
08/20/14 02:32 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Well I can tell you that I have a car front cover,alt and water pump. I also have a 4.7 truck power steering pulley and it is all 6 rib same same.
Mopar to the bone!!!
