Re: Spark Plug Indexing
[Re: Racer68]
#1658694
08/13/14 11:27 PM
08/13/14 11:27 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Depending on the type of plug you are running. Race plugs have the cut back ground strap, pretty much eliminates shrouding. Standard plugs with long strap will give you something, maybe. I used to do it , now I figure it's a waist of time. But others on here will say they gained a tenth.
[Re: Dodgem]
#1658696
08/14/14 05:09 PM
08/14/14 05:09 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I run the C57CX with race fuel(gas) and the C59CX with alcohol,both have cut back straps and I see no need to index them.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: rowin4]
#1658698
08/14/14 05:42 PM
08/14/14 05:42 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
It is a waste of time for 98% of racers out there UNLESS you have a reason to do it. IE interference between plug and piston.
