School me on a 1 wire alt compared to stock wiring alt #1658506
08/13/14 08:57 AM
08/13/14 08:57 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
Gang:
I'm about to purchase a new alternator for my car. Help me decide on the pro's and con's of a 1 wire alternator compared to factory style. I have all new harness for my car with the electronic ignition, electric choke, no points. I might be getting Alszheimers cause I cant seem to remember.
Any help will be appreciated.
Re: School me on a 1 wire alt compared to stock wiring alt [Re: 71rm23] #1658507
08/13/14 11:31 AM
08/13/14 11:31 AM
No actual 1 wire alt exp but I prefer the old style tho many have used em & are happy. (I likely just dont like drastic changes). with your harness setup for the old style I would go with an 85 M body 78 amp stock one or the big beast with the fan behind the pulley is an option & reportedly works well but it is heavy/unsightly. for a non Mopar, Denso gets good reviews and Andy markets a bracket for it I believe. I like using the large 7.25" crank pulley to spin the alt as fast as possible and this may require a smaller water pump pulley to fit it which spins the pump faster & with an anticav you're fine there also & faster coolant speed is better plus you get a faster fan speed. Just consider this a BTT for ya
Re: School me on a 1 wire alt compared to stock wiring alt [Re: 71rm23] #1658508
08/13/14 12:20 PM
08/13/14 12:20 PM
USA
rftroy Offline
rftroy  Offline
USA
You asked for schooling:
http://www.madelectrical.com/electricaltech/onewire-threewire.shtml
Don't use a one wire alternator.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: School me on a 1 wire alt compared to stock wiring alt [Re: rftroy] #1658509
08/14/14 01:03 AM
08/14/14 01:03 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Robert
Re: School me on a 1 wire alt compared to stock wiring alt [Re: Dabee] #1658510
08/14/14 07:31 AM
08/14/14 07:31 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
RapidRobert- P.M sent
