Gen III Hemi valve locks
#1658338
08/12/14 11:01 PM
08/12/14 11:01 PM
Posts: 148 Albert Lea, MN
GTX5877
Albert Lea, MN
Anyone know of any 10 degree valve locks for the 6.4 triple groove valves? Can find single groove for the .3125" stems, but not triples. Any help is appreciated!
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
Re: Gen III Hemi valve locks
[Re: GTX5877]
#1658339
08/13/14 02:05 AM
08/13/14 02:05 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
What spring are you running? Who's retainer?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1658340
08/13/14 11:09 AM
08/13/14 11:09 AM
GTX5877
Albert Lea, MN
PAC spring and retainer. Retainer is not available in 7 degree.
[Re: GTX5877]
#1658341
08/13/14 04:57 PM
08/13/14 04:57 PM
sixpackgut
Charleston
these guys are in your hood and have helped me a bunch http://sharadon.com/newhemi.htmFWIW, I run stock retainers on my Manley Drag Pack springs with Manley locks. I assemble a lot of heads for LS stuff and its all been 7* for the past several years and haven't had a problem. years ago, there were a lot of spring kits with 10* but I never see it any more
[Re: sixpackgut]
#1658342
08/13/14 05:57 PM
08/13/14 05:57 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I'll be using stock locks and Comp moly retainers on my Manley springs. I dont think there is much choice when running stock valves.
Mopar to the bone!!!
[Re: 72Swinger]
#1658343
08/14/14 02:18 AM
08/14/14 02:18 AM
GTX5877
Albert Lea, MN
The beehive spring I am using has a taller installed height for the longer valves in a 6.4 head and is a little larger in diameter, both top and bottom. The stock retainers are too small. Matching retainer is only available in 10 degree. May have to have some 7 degree retainers made for this spring and use stock locks.
[Re: sixpackgut]
#1658347
08/15/14 08:31 PM
08/15/14 08:31 PM
GTX5877
Albert Lea, MN
Staying conservative to start, .620" lift 267*-273* @ .050. Geometry isn't the best at .650 lift, so taking it easy to start.
