Fool proof timing tape? #1658117
08/12/14 01:08 PM
08/12/14 01:08 PM
Hillsdale,Mi
69swinger340 Offline OP
Hillsdale,Mi
I am on my third timing tape on my dart. The first one peeled the paint off with it, the next one I removed the paint and put it directly on the balancer. That was short lived, both have been cleaned very well. Whats the secret so I won't have to buy a new tape every time I need to adjust my rockers?
*69 swinger 340 4spd *70 T/A 340+6pk 4spd
Re: Fool proof timing tape? [Re: 69swinger340] #1658118
08/12/14 01:11 PM
08/12/14 01:11 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Mark the balancer , skip the tape...
What tape are you using ? I have an MP tape on a 383 balancer that I installed on the balancer in the summer or 1999 ?
Re: Fool proof timing tape? [Re: JohnRR] #1658119
08/12/14 02:08 PM
08/12/14 02:08 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Re: Fool proof timing tape? [Re: 69swinger340] #1658120
08/12/14 02:15 PM
08/12/14 02:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've used the MR Gasket timing tape, never lost one yet, but then again I seal the damper with a coat of clear engine paint after applying the tape to a FRESHLY PAINTED/CLEAN damper
Re: Fool proof timing tape? [Re: DAYCLONA] #1658121
08/12/14 02:24 PM
08/12/14 02:24 PM
Hillsdale,Mi
Hillsdale,Mi
The past two have been MP, this one is a Mr. Gasket. I think i will give the coat of clear on top of it a shot.
Re: Fool proof timing tape? [Re: 69swinger340] #1658122
08/12/14 02:46 PM
08/12/14 02:46 PM
That is the only way I have been able to keep them on, I use several coats also
Re: Fool proof timing tape? [Re: Cab_Burge] #1658123
08/12/14 03:36 PM
08/12/14 03:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Clean clean clean i used lacquer thinner the last times I used tape and it worked great.
Re: Fool proof timing tape? [Re: 69swinger340] #1658124
08/12/14 04:53 PM
08/12/14 04:53 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Or you could buy a quality balancer & be done with it for good. Also good for engine's longevity.
Re: Fool proof timing tape? [Re: 80fbody] #1658125
08/12/14 05:04 PM
08/12/14 05:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
One guy told me once he used his wifes nail polish and he said it worked good to keep it on. Ron
Re: Fool proof timing tape? [Re: 69swinger340] #1658126
08/13/14 04:33 AM
08/13/14 04:33 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Do one cylinder at a time. Adjust the intake when the exhaust starts to open, and adjust the exhaust when the intake begins to close a short ways.
Do one side of the car, then the other. Way easier. No tape needed.
Re: Fool proof timing tape? [Re: DAYCLONA] #1658127
08/13/14 05:29 AM
08/13/14 05:29 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
same here but mine lasted 12 years. I put on another one last season after cleaning the balancer with lacquer thinner....then acetone....then As I laid down the new tape...i laid a bead down of Super Glue and pushed the tape down. Cut a rectangular hole the width of your balancer and 4" long and spray a high strength clear coat from a spray bomb...rotating in intervals to get coverage 3 times. Yeah...I did mine ON the car
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Fool proof timing tape? [Re: 69swinger340] #1658128
08/13/14 07:20 AM
08/13/14 07:20 AM
As said: clean the dampener. pull the tape thru a rag with brake kleen. remove backing/install tape. seal it with several coats of clear lacquer. let dry well. OR use the timing tab as a ruler to make new marks & I only need (4): 10-15-20 and my total for my eng type. Never hurts to confirm exact TDC first. The spark plug hole tool is only $10 or break up a spark plug & drill/tap it. On adj your rockers you could bump the eng till the rotor is at the next plug wire (cap terminal) then adj that cyl or measure a strip of thin paper 5.694" with your calipers then use it as a ruler to make 3 addit'l marks around the dampener from the TDC slit then use these new marks to get the cyls' on TDC. Just me I think those tapes look hokey
Re: Fool proof timing tape? [Re: RapidRobert] #1658129
08/13/14 07:42 AM
08/13/14 07:42 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Have the MSD timing tape on for quite some time, no nail polish, no clear coat. Sticks real good.
