Wheelie Bars at work #1657980
08/12/14 02:34 AM
08/12/14 02:34 AM
Windsor ,Ca.
K
Keith Richards Offline OP
K
Windsor ,Ca.
Here is a compilation of some runs from the weekend , first time out with the new bars on and 60' were pretty much within 3-4/1000 all weekend from 1.268 - 1.272. This is still a mild tune on the pump gas 572 and after coming across a few things late I think there is a bit more left. We will see in the next few weeks.
Richards Racing
Re: Wheelie Bars at work [Re: Keith Richards] #1657981
08/12/14 03:20 AM
08/12/14 03:20 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
nice ride..good to see
you posting again
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Wheelie Bars at work [Re: Stroker Scamp] #1657982
08/12/14 07:46 AM
08/12/14 07:46 AM
gregsdart Offline
gregsdart  Offline
Great looking car! Looks like as the runs progress the rear axle is under better control. I don't see the wheelie bars bouncing much in the last runs.
Re: Wheelie Bars at work [Re: Keith Richards] #1657983
08/12/14 07:53 AM
08/12/14 07:53 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Richards Racing
What wheelie bars?
Re: Wheelie Bars at work [Re: moparguy7074] #1657984
08/12/14 11:39 AM
08/12/14 11:39 AM
Shelton, Ct.
572_HEMI_Cuda Offline
Shelton, Ct.
Richards Racing
What wheelie bars?
In the Video link he posted.
Re: Wheelie Bars at work [Re: Keith Richards] #1657985
08/12/14 09:50 PM
08/12/14 09:50 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Did your car pick up any ET after installing the wheelie bars since it is not picking the front tires as high as before?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Wheelie Bars at work [Re: 572_HEMI_Cuda] #1657986
08/12/14 09:52 PM
08/12/14 09:52 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Rear shock is way to loose on the rebound . The car goes , hop ,hop, hop , after the first hit .
What kind of rear suspension do you have ?
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Wheelie Bars at work [Re: go green] #1657987
08/12/14 10:44 PM
08/12/14 10:44 PM
Windsor ,Ca.
K
K
Windsor ,Ca.
Same ET and Ladder bars with cheap shocks that I do not believe are even made anymore, Avo?
The aluminum 572 pump gas motor just replaced my 14.2/1 compression 501" motor and they run almost identical ET's although this one still has a bit of tweaking to be done for sure as it is lean right now and not much timing in it.They also share identical 60' times with the 4.10 gear that rarely vary more than 3-4/1000 so as bad as the shocks might be it has worked.
Re: Wheelie Bars at work [Re: go green] #1657988
08/13/14 12:35 AM
08/13/14 12:35 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
That's what I saw.
