air filter #1657467
08/11/14 11:46 AM
08/11/14 11:46 AM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
I put a high rise intake on my 360 in my 1970 Dart. I want to use my MP air cleaner. With the stock filter it is hitting the hood. I need to find a 1-1 1/2 IN. filter. I went to NAPA he could not find one in 13 in. diameter that skinny. Thanks for your help
Re: air filter [Re: 70dart318] #1657468
08/11/14 11:49 AM
08/11/14 11:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You do not want to change to a 1.5" tall filter.
Ford Motorsport sells a drop base air cleaner still , saw one in Pepboys the other day , it's 13" and the air filter is the same as what I assume you are using is the MP unsilenced air cleaner.
Re: air filter [Re: JohnRR] #1657469
08/11/14 12:31 PM
08/11/14 12:31 PM
Streetsboro,Ohio
Streetsboro,Ohio
I tried a drop base the regular filter is still to tall. Thanks
Re: air filter [Re: 70dart318] #1657470
08/11/14 12:43 PM
08/11/14 12:43 PM
How tall is the filter in question (that's hitting)
Re: air filter [Re: RapidRobert] #1657471
08/11/14 12:54 PM
08/11/14 12:54 PM
Streetsboro,Ohio
Streetsboro,Ohio
all most 3 inches
Re: air filter [Re: 70dart318] #1657472
08/11/14 01:54 PM
08/11/14 01:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The ford motorsport unit is the ticket then , you will choke off air to the engine wit ha 1.5" filter in that housing , then there will be clearnce issue to your carb possibly. I got one of those air cleaner bases so I could run a TRUE 3" filter element in the unit on an RPM intake.
Re: air filter [Re: JohnRR] #1657473
08/11/14 02:52 PM
08/11/14 02:52 PM
Streetsboro,Ohio
Streetsboro,Ohio
Ok I will look in to the Ford Drop base. The intake I used is also a RPM. Thanks
