93 air conditioning in 73 truck #1657328
08/11/14 04:32 AM
08/11/14 04:32 AM
Austin, TX
lunacy Offline OP
lunacy  Offline OP
Austin, TX
I am fixing to pick me up a 73 club cab truck for a new daily driver. Truck is in beautiful shape, but is a heater only model. I have a buddy with a few 89-93 Cummins trucks sitting around that would get me cheap a/c parts. Has anyone ever tried putting the blower box out of a 92 into a 73? Or am I better off trying to find year correct parts?
Re: 93 air conditioning in 73 truck [Re: lunacy] #1657329
08/11/14 09:18 AM
08/11/14 09:18 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
The firewall holes are different. The 72-80 is shown here.
OIF V and OEF X veteran and proud of it!
Re: 93 air conditioning in 73 truck [Re: 69HemiGTX] #1657330
08/11/14 09:19 AM
08/11/14 09:19 AM
69HemiGTX Offline
69HemiGTX  Offline
81-93
Re: 93 air conditioning in 73 truck [Re: 69HemiGTX] #1657331
08/11/14 11:11 AM
08/11/14 11:11 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I'm putting a 84 firewall in my 77 CrewCab so I can use the later A/C parts that are easier to find & I can put the serpentine system back on the Mag motor & use 92-93 A/C lines & compressor
Re: 93 air conditioning in 73 truck [Re: BulletBob] #1657332
08/11/14 09:03 PM
08/11/14 09:03 PM
Austin, TX
lunacy Offline OP
lunacy  Offline OP
Austin, TX
Looks like for my purposes finding a 73-80 a/c unit would work the best. The truck has fresh motor and paint so I am not looking to tear it all apart. Although I just realized looking at some other pictures that heater only trucks don't have dash vents so I would need to find a dash or put some into the current dash. Maybe I need to see if i can find a used aftermarket under dash setup for cheap, that would probably be easiest.
Re: 93 air conditioning in 73 truck [Re: lunacy] #1657333
08/15/14 12:40 AM
08/15/14 12:40 AM
smyrna,tn
draginmopars Offline
smyrna,tn
we put a 92 LE club cab,
cummins fire wall into a 73 crew cab
so that the car hauler ended up with
A/C, tilt/cruise, pdl,pw, and cummins 5-speed , 3.07 gear
was 440/auto, 4.10
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: 93 air conditioning in 73 truck [Re: draginmopars] #1657334
08/15/14 12:56 AM
08/15/14 12:56 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Vinny, a member here, 66fastback i think.
Put the entire dash and HVAC system from a 93 into a 78. Worked great, and the updated HVAC is much nicer.
Re: 93 air conditioning in 73 truck [Re: hp383] #1657335
08/15/14 01:09 AM
08/15/14 01:09 AM
Nebraska
FASTBACK66 Offline
mopar addict
FASTBACK66  Offline
mopar addict
Nebraska
Just make a template out of carboard and trim the older firewall. Take a little at a time and test fit often. Easy swap.
Re: 93 air conditioning in 73 truck [Re: FASTBACK66] #1657336
08/17/14 04:03 PM
08/17/14 04:03 PM
Austin, TX
lunacy Offline OP
lunacy  Offline OP
Austin, TX
How about the vents and controls, would the dash need to be swapped as well or are the vents adaptable? Since you would have to cut vents into the heater only dash I would think this would work ok, but the controls may be harder to adapt.
