Re: holly two barrel to a rodchestor quad on a 83 d150 318
[Re: Dodge family]
#1656928
08/10/14 05:21 AM
08/10/14 05:21 AM
Posts: 4,848 Memphis
HemiRick
Memphis
The carb and the timing are not related.....Sound like the new carb is not tuned for the 318...or it needs to be gone thru.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Dodge family]
#1656929
08/10/14 06:39 AM
08/10/14 06:39 AM
RapidRobert
Welcome aboard! need more info: what idle speed what timing more detail on how it's acting
[Re: moparborn]
#1656936
08/10/14 07:13 PM
08/10/14 07:13 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Is the vacuum advance hooked up/to the correct port?
If it has ESA, there is no vacuum advance.
[Re: Dodge family]
#1656938
08/10/14 10:34 PM
08/10/14 10:34 PM
RapidRobert
I'd put it in Drive with the Ebrake on then set the timing at 15 with a reasonably slow idle speed & likely need to richen the idle mix screws. Hopefully no vac leak anywhere.
[Re: Dodge family]
#1656940
08/11/14 01:58 AM
08/11/14 01:58 AM
RapidRobert
if it idles good but dont have enough power to continue to idle good when in gear which takes a bit more power I'd guess it (the idle circuit) needs to be richened up (assuming no vac leak) assuming the timing is adequate
