Can a 72 SE Chargers rear windows be changed ???? #165664
12/10/08 09:16 PM
12/10/08 09:16 PM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I found what I think is a 72 SE Charger, but I have'nt seen pic's of it yet to really know. My question is: Can you get rid of the SE style rear quarter windows and make them roll down like a regular charger? What would be involved?
Re: Can a 72 SE Chargers rear windows be changed ???? [Re: High Impact] #165665
12/10/08 11:46 PM
12/10/08 11:46 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
You most certainly can!
There is a factory "filler panel" welded into the standard 1/4 panel. The 72 SE's use standard Charger rear glass and window lifts. You would have to cut out the filler panels and mount up the proper window felts and such. Should be a pretty straight forward process.
Of course, you'd have to change the upper rear sail panels, as they are different. Might have to find a few trim pieces from a 71, or 72 (non-SE) to make it factory.
Re: Can a 72 SE Chargers rear windows be changed ???? [Re: 440trk] #165666
12/11/08 06:47 AM
12/11/08 06:47 AM
Manistee, Michigan.
Manistee, Michigan.
Cool! I was hopeing it could be done and it sounds fairly easy. Thanks
Re: Can a 72 SE Chargers rear windows be changed ???? [Re: High Impact] #165667
12/11/08 02:57 PM
12/11/08 02:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
will need enlarge drip rail and its propper moldings, get interior panels involved ( sail and upper rears ). If intereted, get the belt moldings too. Glass itself is thwe same, no prob on that. Regular new window felt kit.
OH AND SIDE HEADLINER MOLDS
