440 power steering pump brackets #1656585
08/08/14 11:48 PM
08/08/14 11:48 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The hot rod buyer has asked me to source the goods necessary to install power steering on the hot rod.
The engine is a 1972 440 with a factory damper. How hard is it to find the non-A/C power steering pump brackets?
I have a collection of crank pulleys so one of those should line up.
- Stu Harmon
Re: 440 power steering pump brackets [Re: feets] #1656586
08/09/14 12:07 AM
08/09/14 12:07 AM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
The power steering pump brackets are being reproduced and are readily available for the saginaw pump. 440source sells complete kits as well as many others like year one,classic industries, Many of the Mopar specific vendors that advertise here sell the also.
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: 440 power steering pump brackets [Re: Ray440] #1656587
08/09/14 12:12 AM
08/09/14 12:12 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Thanks.
I never had to shop for such luxuries before.
- Stu Harmon
Re: 440 power steering pump brackets [Re: Ray440] #1656588
08/09/14 12:15 AM
08/09/14 12:15 AM
Georgia
Steve Bryant Offline
Georgia
I got mine from 440Source and they look terrific but the 3/8 square was a little too tight for my ratchet so I had a slightly more difficult time tightening the belt.
If you look closely you will see a little square. I am 99% sure that is where you would insert a 3/8 ratchet and crank it up to put tension on the belt. Well, the square was too tight so either I have no idea what that square is for or they made it too small.
It's really not a big deal and I would buy them again.
Re: 440 power steering pump brackets [Re: Steve Bryant] #1656589
08/09/14 07:51 PM
08/09/14 07:51 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
That is a chineese 3/8" hole
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 440 power steering pump brackets [Re: astjp2] #1656590
08/09/14 11:40 PM
08/09/14 11:40 PM
Georgia
Georgia
Astjp2, that is exactly what I was saying to myself as I was trying to tighten up the belt.
