Page 3 of 3 1 2 3
Re: Need to repair one broken piston - cheaply. [Re: Fab64] #1656468
08/21/14 02:31 PM
08/21/14 02:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Post your bore size and I will see if I have a spare piston.
Re: Need to repair one broken piston - cheaply. [Re: HotRodDave] #1656469
08/21/14 03:02 PM
08/21/14 03:02 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks, Dave. I have not yet ordered a new piston from Rockauto. Unfortunately, they don't have any std-sized rings for a single-piston left, just complete sets (for all eight).
I need one standard-size piston with rings for a 1966, non-HiPo 383, bore size 4.25". This motor came out of a Chrysler, and the block does not appear to have been bored over-size. If you have a spare piston with rings on it, I would happily pay the shipping.
Re: Need to repair one broken piston - cheaply. [Re: HotRodDave] #1656470
08/21/14 07:03 PM
08/21/14 07:03 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just a thought, maybe it swallowed something that broke those ring lands that way?
Re: Need to repair one broken piston - cheaply. [Re: Fab64] #1656471
08/21/14 10:36 PM
08/21/14 10:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I'm guessing there may have been an intake manifold leak at the #7 cylinder, which caused that one to run way hot.
Have you tried to wrap any logic around that statement?
My bro-in-law, a retired mechanic, is the one who suggested this. He has seen instances of intake manifold leaks causing such things. A leak at the intake runner for #7, where the manifold meets the head, would allow outside air to be pulled into the cylinder, diluting the a/f mixture, thus leaning out that cylinder, and causing it to run hot. Since none of the other pistons show any obvious signs of either abuse or overheating, this sounded like a logical and reasonable explanation for what might have caused this issue. Does this not sound possible to you? He wasn't saying this is definitely the cause. If you ask five people on this board, you may get five different explanations.
And likely not that one, or at least I would hope not............ well maybe.
Page 3 of 3 1 2 3
