Thrust Button In Differential
#1656359
08/08/14 12:45 PM
08/08/14 12:45 PM
Posts: 5,166 CT
GTX MATT
CT
Alright, so whats the deal with the thrust button inside of the sure grip unit? Is it needed? When does it need to be removed? I'm putting one into a diff with stock axle bearings, for what its worth. Is it going to need to come out?
Re: Thrust Button In Differential
[Re: GTX MATT]
#1656362
08/08/14 01:10 PM
08/08/14 01:10 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
The buttons are used as "spacers" in between the two axles once they are assembled with stock bearings. You need them to be able to get the proper axle end play with your adjusters. When you remove the axles, they might fall out into the housing. If so, just clean them off and find a spring pin to fit them together, and put them back in. The pin just helps keep them together during assembly of the axles.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1656363
08/08/14 03:09 PM
08/08/14 03:09 PM
Posts: 5,166 CT
GTX MATT
CT
Alright great, all of this green bearing talk lately is getting me confused, I didn't remember it ever being a problem before
