Re: Anyone actually done the CrownVic swap into Sweptline?
[Re: 72d100]
#1656100
08/08/14 12:49 PM
08/08/14 12:49 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Some have done it. There are a couple on Sweptline.org.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: 72d100]
#1656101
08/08/14 03:26 PM
08/08/14 03:26 PM
Posts: 711 San Francisco
dilvoy
San Francisco
02 and earlier you have to cut the frame and splice in and 03 up have bolt in crossmember
I think that 02/03 was the split when they went from steering box to rack and pinion steering.
[Re: dilvoy]
#1656102
08/08/14 04:41 PM
08/08/14 04:41 PM
Posts: 4,152 Canada -- Posts: 4034 -Registe...
5thAve
It all happened at the same time.
[Re: dogdays]
#1656104
08/09/14 07:17 PM
08/09/14 07:17 PM
Posts: 1,179 Canada
demon
Canada
87-91 Dakota front frame splice is a great way to go on a sweptline. Rack and pinion steering, independent, sway bar, disc brakes, proper bolt pattern, MOPAR, cheap and the frames are the same width. And yes the track width is almost exactly the same. Dakota's use a unique positive offset wheel. Bolt on a "normal" wheel and the track width is virtually the same as a sweptline.
