U are making it complicated with the math..
1st point is to make sure U have the rite Z-bar, the tab that drives the pushrod to the fork so the pushrod should be parallel to the bellhousing. My Roadrunner had the wrong Z-bar creating incorrect and harder leverage. There are (3) different Mopar Z-bars in the rite width but the tab position varies. Then the other crucial point is throw-out bearing to finger clearance, should be @ least 0.050". Also be sure to use the proper return spring as speced by Mopar, not some universal type.
Just my $0.03...
