Prime first or filler first ??? #1656037
08/07/14 04:52 AM
08/07/14 04:52 AM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
I'm doing some body work and would like to hear your opinions as to which should come first. Primer or filler ??? Or does it matter ?
Re: Prime first or filler first ??? [Re: 62440] #1656038
08/07/14 11:36 AM
08/07/14 11:36 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
It matters! Prime first.
Re: Prime first or filler first ??? [Re: Stanton] #1656039
08/07/14 02:15 PM
08/07/14 02:15 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I use etching primer, then filler, then high build primer.
Re: Prime first or filler first ??? [Re: 62440] #1656040
08/07/14 02:29 PM
08/07/14 02:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
metal work, then filler, then etch primer, or epoxy coat, then high build primer, then sealer and/or base color/clear coat, or single stage depending on the requirements....been doing it this way for 35+ years
Re: Prime first or filler first ??? [Re: moper] #1656041
08/07/14 02:32 PM
08/07/14 02:32 PM
USA
hudsonhornet7x Offline
USA
I will assume that all rust is gone from your area.
1. Clean the surface before any grinding.
2. Prep the bare metal with 80 grit grinder discs or D.A. paper.
3. Epoxy prime the bare metal and follow the instructions on how long it should wait before you apply filler.
4. Finish bodywork and re epoxy prime to seal it all in.
Re: Prime first or filler first ??? [Re: hudsonhornet7x] #1656042
08/07/14 02:41 PM
08/07/14 02:41 PM
dogdays Offline
dogdays  Offline
Back in the day, filler went on clean metal first. The surface roughness supposedly helped the filler "grab" onto the surface.
It seems that things have changed, possibly due to the advent of epoxy primer.
The real answer is to use a bodywork material system and do whatever the system instructions say.
R.
Re: Prime first or filler first ??? [Re: dogdays] #1656043
08/07/14 06:52 PM
08/07/14 06:52 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
On a small area I like to brush on a rust encapsulator. It acts as a sealer and if you miss any rust its caught.
Re: Prime first or filler first ??? [Re: hudsonhornet7x] #1656044
08/07/14 11:33 PM
08/07/14 11:33 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
This is the best way now.
Re: Prime first or filler first ??? [Re: stinger] #1656045
08/08/14 12:39 AM
08/08/14 12:39 AM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
Thanks for all the replies. I went down to the local Napa auto parts store today and asked him. I mentioned that I heard different opinions on the subject and he started laughing and said that's a good way to get a argument started. I'll go with two coats etch primer and filler, two more regular primer coats and then final coats. Thanks again.
Re: Prime first or filler first ??? [Re: 62440] #1656046
08/08/14 12:57 AM
08/08/14 12:57 AM
USA
USA
To each his own, but I would never put filler over etch primer. Lots of polyester fillers can have a bad reaction with the acid in etch primer. This may not show up right away but a few months down the road. Loss of adhesion, bubbling, etc. Only put filler over properly prepared bare steel or better yet over properly prepared epoxy primer.
If it is a car you care about, please use a good epoxy. I am an auto body teacher and have used just about every method available.
Here is what it boils down to:
Collision shops: Love etch primer because it is fast and has been used forever. They are not too worried about a paint job lasting 20 years. Epoxy is too slow for the fast paced collision business even though it is a superior product.
Restoration Shops: Love epoxy primer because it the best primer bar none. It takes a little while to cure but it has better adhesion, IS NOT POROUS, and filler absolutely loves to stick to curing epoxy. Spraying epoxy again over filler completely seals it in.
The thing about body filler is it is like a sponge, and if you use it on bare steel there is a very good chance that it will suck some moisture and start the rust bug again. This will happen right through etch primer.
Like I said, it boils down to you and what kind of job you want to do.
If anyone has any questions please ask- I will be happy to answer anything I can.
Re: Prime first or filler first ??? [Re: hudsonhornet7x] #1656047
08/08/14 10:11 PM
08/08/14 10:11 PM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
That sounds like the best way. I'll save the etch primer for something else and pick up some epoxy primer and do it right. Thanks again.
