255/60 or 275/60 I can't decide #1655923
08/06/14 11:24 PM
08/06/14 11:24 PM
Indiana
68_661charger Offline OP
Indiana
Its going on a b body 15x8 rim with 323 gears. Would I be able to tell a difference in performance between the two? Or is the difference in looks all im dealing with here?
Re: 255/60 or 275/60 I can't decide [Re: 68_661charger] #1655924
08/06/14 11:41 PM
08/06/14 11:41 PM
IN
ahy Offline
ahy  Offline
IN
The 255/60/15 looks like about a 27" tire and the 275 closer to 28". As far as performance, I guess it depends on what you are after. The shorter tire will sightly reduce overall gearing and (very) slightly improve acceleration. The wider 275's may (slightly) improve launch if you have plenty of HP.
I think its mostly looks (and fit). I would think 275's would be tight in the rear and no go on the front. Measurements would need checked and backspace dialed in just right to fit the 275's if the sheetmetal and ride height are stock'ish.
In general, either tire is on the tall side. With 3.23's the taller tires favor cruising vs acceleration unless you have a really big or boosted engine.
Re: 255/60 or 275/60 I can't decide [Re: ahy] #1655925
08/06/14 11:45 PM
08/06/14 11:45 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
which b-body?
Re: 255/60 or 275/60 I can't decide [Re: 6bblgt] #1655926
08/06/14 11:51 PM
08/06/14 11:51 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
I run 275s on a 69 B body on factory 15x8 rims with no clearance issues.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 255/60 or 275/60 I can't decide [Re: EWJ] #1655927
08/06/14 11:59 PM
08/06/14 11:59 PM
Indiana
Indiana
68 Charger basically a stock 383
Re: 255/60 or 275/60 I can't decide [Re: 68_661charger] #1655928
08/07/14 12:31 AM
08/07/14 12:31 AM
Central NC
gch Offline
gch  Offline
Central NC
Go with the 255/60 although I usually run that on a 7" rim.On a stock 383 with 3.23 gears I would want the shorter tire myself.
Re: 255/60 or 275/60 I can't decide [Re: gch] #1655929
08/07/14 02:35 AM
08/07/14 02:35 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I love the 275 60 15s on an 8 in rim for my 68 Charger.
Compared to modern cars, a 323 is a bit buzzy, the taller 275s help with that..
Re: 255/60 or 275/60 I can't decide [Re: sthemi] #1655930
08/07/14 11:36 AM
08/07/14 11:36 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
definitelly 255/60
Re: 255/60 or 275/60 I can't decide [Re: NachoRT74] #1655931
08/07/14 06:48 PM
08/07/14 06:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
295/50's on the back of mine. I wanted the nice wide tire look but didn't want it sitting all jacked up from too tall of a tire.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 255/60 or 275/60 I can't decide [Re: 6PKRTSE] #1655932
08/07/14 07:28 PM
08/07/14 07:28 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
275 looks tougher, but with 3.23s and a 383 in front of it you likely won't be happy with how unresponsive it seems.
Re: 255/60 or 275/60 I can't decide [Re: GTX MATT] #1655933
08/07/14 07:55 PM
08/07/14 07:55 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Get the tire you want, but dont be too concerned about gearing. The ONE inch height difference equates to 3.7% in gearing. In other words, if you had a 3.23 27" tire car to start with, installing a 28" tire would have the same effect as switching to a 3.35 gear ratio (if such a ratio existed).
Or yet another way of looking at it, 3000rpm with a 27" would have to become 3111 rpm for the same MPH.
Re: 255/60 or 275/60 I can't decide [Re: 68_661charger] #1655934
08/07/14 08:44 PM
08/07/14 08:44 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
275/60. Anything less will look small on a 68 charger.
Re: 255/60 or 275/60 I can't decide [Re: Pacnorthcuda] #1655935
08/08/14 12:51 AM
08/08/14 12:51 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Can you explain the math behind this? As a common rule of thumb I've always figured 1" of tire to be about 6.5 points of gear. Your number is about double.
...FAFO...
Re: 255/60 or 275/60 I can't decide [Re: skicker] #1655936
08/08/14 01:02 AM
08/08/14 01:02 AM
27 x 3.14159 = 84.8" traveled.
28 x 3.14159 = 88.0" traveled
88.0/ 84.8 = 1.0377. Significant figures not paid attention to of course.
3.77 % difference.
Re: 255/60 or 275/60 I can't decide [Re: 68_661charger] #1655937
08/08/14 05:44 PM
08/08/14 05:44 PM
Eugene, OR
FuryBoy Offline
FuryBoy  Offline
Eugene, OR
Have you looked at 255/70s? Great for road trips!
Re: 255/60 or 275/60 I can't decide [Re: FuryBoy] #1655938
08/08/14 07:11 PM
08/08/14 07:11 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
with no clearance issues with either on a 72 B body ive really liked either the 275-60/15 or the 295-50/15 both on a 8 inch wheel..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: 255/60 or 275/60 I can't decide [Re: 72N96RR] #1655939
08/08/14 11:33 PM
08/08/14 11:33 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
One needs to consider if future tire rotation is going to happen. I like to have the ability to rotate my tires, can't do that if you have different size tires. I think, the best all-around, on 4-corners is 255/60/15's. If one goes to the 275's up front, you'll probably be rubbing the framerails. Now, if you could care less about being able to rotate tires, I did like the 275's on 15x8's on the rear of my former '69 Charger 500 and 255's up front on 15x7's ( Magnum 500's )
my
Troy
Houston Mopar Connection Club
Re: 255/60 or 275/60 I can't decide [Re: Pacnorthcuda] #1655940
08/09/14 10:45 PM
08/09/14 10:45 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Your math is correct, but your application is backwards. A taller tire (28") would give you a ratio closer to 3.11 NOT 3.35 when compared to a 27" tire 3.23 ratio. Installing a taller tire is effectively like going with a numerically lower gear ratio.
