Re: LRE/warlock bucket seat foam
[Re: LilRed7879]
#1655797
08/08/14 12:34 AM
08/08/14 12:34 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
As far as I know you will not find any "new" pre-cut foam available. You upholsterer should be able to cut foam for you and get it right though.
Yah I was kinda figuring that would be the case. But I had to ask.
[Re: dynotune440]
#1655801
08/11/14 03:55 AM
08/11/14 03:55 AM
bigblock340power
Elk Grove, Calif.
What Sam, no comment!?
I would just be saying the same thing you already know, so I figured I would sit back and have some popcorn.... Good to hear about the parchment samples....
Yup! As soon as I get the Duster squared away (putting the roller-ized short block in tomorrow. Then put it back in the garage.), I'll be getting at the truck a bit harder. Mostly want to make it a little more friendly to the eye.
[Re: wicked872]
#1655803
10/17/14 06:06 AM
10/17/14 06:06 AM
bigblock340power
Elk Grove, Calif.
if you haven't found any yet, I may have a complete foam for one seat with a little bit of damage and one complete seat with the upholstery still on, will have to dig through the garage to look, let me know.
Thanks, but the seats are all done, and in.
