LRE/warlock bucket seat foam #1655794
08/06/14 06:58 PM
08/06/14 06:58 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
Does any one know where to get LRE/warlock bucket seat foam? I know Legendary doesn't make it. But I'd sure like to find some (two)! Or buy from some ones stash/NOS before I go to the upholster.
Oh, Sam, I know you'll most likely see this and comment. But I had to try here.
Re: LRE/warlock bucket seat foam [Re: bigblock340power] #1655795
08/06/14 08:34 PM
08/06/14 08:34 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Is it really specific or can you cut newer less likely to breakdown foam/padding from the upholsterer?
Re: LRE/warlock bucket seat foam [Re: bigblock340power] #1655796
08/07/14 02:19 PM
08/07/14 02:19 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
As far as I know you will not find any "new" pre-cut foam available. You upholsterer should be able to cut foam for you and get it right though.
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
Re: LRE/warlock bucket seat foam [Re: LilRed7879] #1655797
08/08/14 12:34 AM
08/08/14 12:34 AM
Elk Grove, Calif.
Elk Grove, Calif.
Yah I was kinda figuring that would be the case. But I had to ask.
Re: LRE/warlock bucket seat foam [Re: bigblock340power] #1655798
08/10/14 09:30 PM
08/10/14 09:30 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: LRE/warlock bucket seat foam [Re: dynotune440] #1655799
08/10/14 10:47 PM
08/10/14 10:47 PM
Elk Grove, Calif.
Elk Grove, Calif.
What Sam, no comment!?
Re: LRE/warlock bucket seat foam [Re: bigblock340power] #1655800
08/11/14 03:28 AM
08/11/14 03:28 AM
dynotune440 Offline
dynotune440  Offline
I would just be saying the same thing you already know, so I figured I would sit back and have some popcorn....
Good to hear about the parchment samples....
Re: LRE/warlock bucket seat foam [Re: dynotune440] #1655801
08/11/14 03:55 AM
08/11/14 03:55 AM
Elk Grove, Calif.
Elk Grove, Calif.
Yup! As soon as I get the Duster squared away (putting the roller-ized short block in tomorrow. Then put it back in the garage.), I'll be getting at the truck a bit harder. Mostly want to make it a little more friendly to the eye.
Re: LRE/warlock bucket seat foam [Re: bigblock340power] #1655802
10/16/14 11:23 PM
10/16/14 11:23 PM
Wisconsin
W
wicked872 Offline
wicked872  Offline
W
Wisconsin
if you haven't found any yet, I may have a complete foam for one seat with a little bit of damage and one complete seat with the upholstery still on, will have to dig through the garage to look, let me know.
Re: LRE/warlock bucket seat foam [Re: wicked872] #1655803
10/17/14 06:06 AM
10/17/14 06:06 AM
Elk Grove, Calif.
Elk Grove, Calif.
Thanks, but the seats are all done, and in.
