Pics needed of Meyers plow setup. #1655672
08/06/14 11:09 AM
08/06/14 11:09 AM
NH
torredcuda Offline OP
NH
I have a diagram of the frame but need pics of the underhood parts - brackets, pump, controls etc. If anyone has some nice clear pics that they could send to me it would be great! Also is there a way to tell which model I have so maybe I can get a factory diagram of it?
Re: Pics needed of Meyers plow setup. [Re: torredcuda] #1655673
08/06/14 11:35 PM
08/06/14 11:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Would help to know what year truck we are dealing with, and if that plow setup you seek info for is a factory installed unit or an aftermarket setup. Lots of changes on Meyer plows through the years, and quite a difference between what was a Mopar installed plow and what some large aftermarket company installed. Gene
Re: Pics needed of Meyers plow setup. [Re: poorboy] #1655674
08/07/14 11:06 AM
08/07/14 11:06 AM
NH
NH
not 100% sure but it looks like a factory installed setup, 1975. ANy pics from around that year would help me identify exactly what it is.
Re: Pics needed of Meyers plow setup. [Re: torredcuda] #1655675
08/07/14 12:31 PM
08/07/14 12:31 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Can you post pics?
Re: Pics needed of Meyers plow setup. [Re: 76dodgeboy] #1655676
08/07/14 02:30 PM
08/07/14 02:30 PM
NH
NH
The problem is there are 5-6 trucks all sitting for years and half torn apart with some plow parts on one truck and some on others. I`m trying to piece together a complete matching system but don`t know exactly what I need. I can post pics of what I have now underhood on the `75 and will be picking up the `76 with the frame and more stuff on sunday.
Re: Pics needed of Meyers plow setup. [Re: torredcuda] #1655677
08/08/14 12:53 AM
08/08/14 12:53 AM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
Re: Pics needed of Meyers plow setup. [Re: scannman70] #1655678
08/08/14 12:54 AM
08/08/14 12:54 AM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
2
Re: Pics needed of Meyers plow setup. [Re: scannman70] #1655679
08/08/14 12:54 AM
08/08/14 12:54 AM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
3
Re: Pics needed of Meyers plow setup. [Re: scannman70] #1655680
08/08/14 12:55 AM
08/08/14 12:55 AM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
Re: Pics needed of Meyers plow setup. [Re: scannman70] #1655681
08/08/14 12:58 AM
08/08/14 12:58 AM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
Pics from my 1980 Sno Commander
Re: Pics needed of Meyers plow setup. [Re: scannman70] #1655682
08/09/14 08:08 AM
08/09/14 08:08 AM
NH
NH
Thanks but I think my setup is different. I did find this diagram.
Re: Pics needed of Meyers plow setup. [Re: torredcuda] #1655683
08/12/14 12:55 PM
08/12/14 12:55 PM
Your diagram pretty much matches his pictures and pretty much matches my frankenplow. His pics dont show the resevoir (item 9 in diagram) that mounts next to the battery.
There were two different types of valve assemblies used but not sure if its a year thing and pretty sure they interchange. It just normal hydralic valves really. The thing thats missing from your diagram but shown in his pics is that the power steering pump gets relocated to the normal a/c compressor location. The engine driven hydro pump is a C body power steering pump with a different resevoir config and the tricky part here is the mounting brackets and the idler pulley.
