edelbrock carb issues #1655567
08/05/14 11:12 PM
08/05/14 11:12 PM
albemarle, NC
dusterbd13 Offline OP
albemarle, NC
so ive ben fighting carb issues in my duster for a while. its bad enough to where ive all but stopped driving it.
idle mixture is set properly with a vacuum gauge, with the ac compressor on, fully warmed up.
electric fuel pump, regulated to 5.5 psi.
floats set to 1/2 from the carb gasket to the top of the float with the cover inverted.
stock jets, rods, and springs.
3/8 thick insulating carb gasket.
air gap intake
so my issues are a few fold.
1. will not restart hot. seems to be vapor locking.
2. doesn't pull nearly as hard as with the 850 double pumper I had.
3. erratic idle with ac compressor on.
4. diesels on cutoff.
while adjusting float level tonight in a vain attempt to solve the hot start issue, I forgot to put the metering rods and springs back in. no covers either. the car ran significantly better when I got on it. almost like the old double pumper. I was excited. when I put the rods back in, it was back to its same old tricks. I don't know if it was all in my head, but with no rods or covers the hot start issue seemed all but gone, but I didn't really validate that well. also didn't seem to even think about dieseling.
so what am I missing? im thinking that the rod and jet combo is way too lean, causing most my troubles, and the springs too stiff. does this sound right?
please, help me out here. I just want to finish out until my leg surgery driving this car.
Michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: edelbrock carb issues [Re: dusterbd13] #1655568
08/05/14 11:36 PM
08/05/14 11:36 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Any out of the box AFB or AVS Eddy is totally jetted wrong for small block or b/rb mopars. Give up a baseline of cid and and a stock jetting for that motor will be advised.
Re: edelbrock carb issues [Re: Pynzo] #1655569
08/05/14 11:38 PM
08/05/14 11:38 PM
albemarle, NC
albemarle, NC
360 with indy heads, solid roller. made 390 rwhp on the dyno with the 850 holly and a single plane. now running the dual plane and the eddy.
5 speed, 3.55 gears, 3400 lbs
Re: edelbrock carb issues [Re: dusterbd13] #1655570
08/06/14 12:20 AM
08/06/14 12:20 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Good info but what Eddy are you using? Stock AVS jetting for a '69 340 and 383 is an .089 primary for a 630 cfm carb. What are you trying to run? Set your baseline jetting to stock figures and build from there.
Re: edelbrock carb issues [Re: dusterbd13] #1655571
08/06/14 01:11 AM
08/06/14 01:11 AM
reset floats to 7/16" and go 3 thou richer on the jets. Which eddy? what springs/what cam/what idle speed. EDIT richen the idle mixture screws
Re: edelbrock carb issues [Re: RapidRobert] #1655572
08/06/14 08:48 AM
08/06/14 08:48 AM
scratchnfotraction Offline
if it ran well with no needles/step up pistons/covers in the pimary jets it is way lean and that made it more than fat with a huge vac leak.
I just went from a 600 eddy to a holley 6210 650cfm spredbore dbl pumper and cant believe how much better mine runs.
ditch the eddybroke
Re: edelbrock carb issues [Re: scratchnfotraction] #1655573
08/06/14 09:09 AM
08/06/14 09:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Then put that back on.
Coming soon!!!!
Re: edelbrock carb issues [Re: Mr.Yuck] #1655574
08/06/14 12:46 PM
08/06/14 12:46 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Yep! or any Holley. There's more threads around complaining about the eddy carbs. I know the Eddy lovers will chime in but......oh well,here's some info for ya
https://board.moparts.org/ubbthreads/show...e=3#Post8218208
Re: edelbrock carb issues [Re: scratchnfotraction] #1655575
08/06/14 01:17 PM
08/06/14 01:17 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Eddybroke
Master, again and still
Re: edelbrock carb issues [Re: dusterbd13] #1655576
08/06/14 03:43 PM
08/06/14 03:43 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I have always been able to get an engine to run little harder with a Holley but have much better manners and mpg with the CarterBrocks.
Since I don't race it was an easy decision. AFB wins.
The AFB is no harder to tune than a Holley. The same basic problems happen with each style of carb. Some issues show themselves in different ways.
It really helps to have eyes and hands on the carb to be able to determine the problem. It could be something as simple as a poor vacuum signal to the carb due to the lumpy cam. If the primaries are opened too far at idle it can uncover the transfer slots. When that happens you'll never get it running right.
1/2" is too deep for the floats. Back that down a bit as suggested.
Get the front end dialed in for good cruise and idle. Leave the back half for making power.
1. Could be an ethanol fuel issue. The AFB fuel bowls sit directly above the manifold and aren't as isolated as the Holley carbs.
2. It should give close performance but the much larger Holley will likely make more power. In fact, I bet the 850 would pull harder than a Holley sized to match the AFB.
3. A/C compressor is going to pull either carb down. Basic physics there. If it didn't impact the 850 as much it was a sign that you likely had the idle tuned less than perfect.
4. Dieseling on cutoff is likely due to hot fuel and/or excessive timing.
The Carter AFB has a better reputation than the Edelbrock. The Eddy 750 has been a poor performer since inception due to poor reverse engineering. I understand the larger AFB has a better reputation.
Eddy carbs have different jetting out of the box based on manual or electric choke.
- Stu Harmon
Re: edelbrock carb issues [Re: dusterbd13] #1655577
08/06/14 05:53 PM
08/06/14 05:53 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
air gap intake
Michael
#1 is a known edelbrock issue, GOOGLE
Edelbrock heat soak,
Edelbrock, hot start,
Edelbrock percolating
#2 There is a large difference between a 600 and 850 CFM so I am not surprised. My thought is the 600 may be a sit small while the 850 is too large.
#3 Tuning issue or may need an idle step up solenoid
#4. Tuning, idle is too high, see #1
Re: edelbrock carb issues [Re: dusterbd13] #1655578
08/08/14 04:27 AM
08/08/14 04:27 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
My 1970 Duster 360/904/3.91 combo with a Comp 280H cam, Weiand high rise manifold, Hooker headers ran great with a 750 cfm Eddy #1407. Great throttle response and no problem with hot starts. I always held the pedal halfway or so to the floor on hot starts. On cold starts after the car sat for a few days I cranked it over several times before pumping the gas pedal then it fired right up. Today's gas makes things tricky besides a good carb tuning and don't forget the importance of correct ignition timing for your combo.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
