MP Distrubutor Schooling Needed! #1655011
08/04/14 04:10 PM
08/04/14 04:10 PM
North Austin
KnuckleDuster Offline OP
North Austin
Please tell me how to set this up correctly for my car.
Bought new,but with no box or instructions...
Please tell me what you need to know to tailor it to my application.
Thanks!
Re: MP Distrubutor Schooling Needed! [Re: KnuckleDuster] #1655012
08/04/14 04:36 PM
08/04/14 04:36 PM
MA
ragtop Offline
ragtop  Offline
MA
I also would like to do the same thing. I would like to know how to change the advance springs and how to swap out VAC cans.
Re: MP Distrubutor Schooling Needed! [Re: ragtop] #1655013
08/04/14 05:31 PM
08/04/14 05:31 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Old style with slot plate:
If you know what the car needs for initial, which should be first up, and total, then it's easy math and a little work.
http://www.moparmusclemagazine.com/techa...em/viewall.html
Modifying advance slots
degrees / slot size
MUTLIPLY by 2 to get crankshaft degrees
6.............. .340
7................355
8................375
9................390
10...............405
11.5 ...........420
12...............435
13...............445
14...............460
15...............475
16...............490
17...............505
18...............520
Newer mallory style.
Same take apart procedure, use drill bit shanks to hit the mechanical advance instead of the mallory keys. The sizing is posted somewhere on the site.
https://board.moparts.org/ubbthreads/show...amp;Search=true
MRG 925 springs seem to work well for a quicker advance curve.
Re: MP Distrubutor Schooling Needed! [Re: ragtop] #1655014
08/04/14 05:33 PM
08/04/14 05:33 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Same here...waiting.... school us...
...FAFO...
Re: MP Distrubutor Schooling Needed! [Re: KnuckleDuster] #1655015
08/04/14 08:19 PM
08/04/14 08:19 PM
(1) set initial with "vacuum gauge method" (2) that's a SB dist so weld/file slots to get 35 total (initial above plus slot length (mechanical) advance (31 if mag heads) (3) toss the heavy spring with elongated loop on one end & sub in a mr gasket or MP light spring (keep the other OE light spring in there) & mix/match springs till you are just under the pinging point at WOT up thru the gears on your hottest/driest (most likely to ping) day and you want the curve to start no less than 200 RPM above your hot in gear idle speed.(4) Then plug in/adj the vac can staying just under the pinging point in everyday driving under varying load (in hg) conditions on your hottest/driest (most likely to ping) day and CCW with a 3/32" allen wrench slows the curve (not the total). On #2 File the welded slots slightly less than the chart as it reportedly is a bit off & you will be in and out of the dist several times (at least) till you get it spot on but it is worth it & you dont want to have to make a return trip to your welder.
Re: MP Distrubutor Schooling Needed! [Re: KnuckleDuster] #1655016
08/05/14 12:00 AM
08/05/14 12:00 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
The pix shows a Mallory / MP unit (note brass). These are an exercise in futility...this info comes right from the engineer who was tasked with "downsizing" Mallory's GM HEI setup to fit a Mopar (small diameter) housing. The flyweights are so light that the springs must also be featherweights. Result: At any point "on the curve" (from just above idle to "all in"), the timing is extremely unstable. There's no fix for this.
Early versions of this dist. were also erroneously shipped with a very fast, long curve, usually resulting in extreme detonation if your combo required more that 5 deg. initial timing. I finally convinced them to fix the "out of the box" curve around 2008, but, as I said, there's no known fix for the spark scatter.
Rick
Re: MP Distrubutor Schooling Needed! [Re: Rick_Ehrenberg] #1655017
08/05/14 01:14 AM
08/05/14 01:14 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Rick
Were earlier units (mid 90's) screwed up as well?
Re: MP Distrubutor Schooling Needed! [Re: pushbutton] #1655018
08/05/14 10:04 AM
08/05/14 10:04 AM
Marlboro, NY, USA
Marlboro, NY, USA
If you see the brass shaft, and quick-adjust weight stops, it is the Mallory design, and you are pi**ing into the wind. I can't remember when they went to that, but it was just about the time when Chrysler's Indianapolis Electrical closed up and they could no longer source the OEM design. Late '90s, maybe?
At the time, I thought "great, how much easier....", then the dirty truth was revealed, backed up by a decade of dyno tests and trying to tune street cars.
What do I do now? If you don't want to go aftermarket (Fire Core, etc.), then use a reman stock '72 distributor for your app (A, B, RB) and tune the old PITA, but rock-solid way.
Rick
Re: MP Distrubutor Schooling Needed! [Re: Rick_Ehrenberg] #1655019
08/05/14 11:11 AM
08/05/14 11:11 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Rick
Thanks, Not having a problem. Mine are mid 90's units.
Re: MP Distrubutor Schooling Needed! [Re: Rick_Ehrenberg] #1655020
08/05/14 11:34 AM
08/05/14 11:34 AM
The pix shows a Mallory / MP unit (note brass). Rick
Hello Rick & thanks for the ID tip as I was wondering how to (easily) tell the difference between the two since I ain't never worked on (or even seen) one of those Mallory based units (I thought that brass colored tip was a bit odd ).
Re: MP Distrubutor Schooling Needed! [Re: RapidRobert] #1655021
08/05/14 01:22 PM
08/05/14 01:22 PM
North Austin
North Austin
Thanks guys!
Bummer though... at least I paid way less than retail, but still....
Rick, if it were your car, what would you use? Stock or aftermarket doesn't matter to me, I just want it to work right!
Primarily a street car, may start seeing the track a couple times a year when it's sorted out though.
Re: MP Distrubutor Schooling Needed! [Re: KnuckleDuster] #1655022
08/05/14 03:14 PM
08/05/14 03:14 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
i had the problem Rick describes with the Mopar/Mallory unit.It came with very light springs and mech advance was all in at 1800 rpm.I replaced them with heavier springs (i think grey and purple) and now mechanical advance is all in at about 2800 rpm and it works fine now.
..just sayin'
Re: MP Distrubutor Schooling Needed! [Re: can.al] #1655023
08/05/14 11:40 PM
08/05/14 11:40 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I'll have to keep an eye out for one of them so I can play with it on my Allen Synchrograph.
Re: MP Distrubutor Schooling Needed! [Re: convx4] #1655024
08/08/14 05:05 PM
08/08/14 05:05 PM
North Austin
North Austin
Here is what I have to work with, can I build what I need from these 4? I know two are points but I included them for possible interchange,especially to show the different vacuum pods. One electronic with the tag appears factory 72 but didn't run the numbers...should I just clean it up or rob parts?
This is fresh territory for me, just want to learn... THANKS !
Re: MP Distrubutor Schooling Needed! [Re: KnuckleDuster] #1655025
08/08/14 08:12 PM
08/08/14 08:12 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
You don't need no fancy machine....
see: http://speedtalk.com/forum/viewtopic.php?p=207546
Here is the pic of what I built: http://i171.photobucket.com/albums/u286/1fastmopar/DSCN0234Large.jpg
I don't have an pics at work, but it works well...
I used an innovative motorsports LM-3 to record the spark timing and I could create a 3D plot of the curve as a function of RPM and vacuum
You could also just use a timing light... Plus you can fire all the plugs which is cool as well...
and it is also a chair...
Re: MP Distrubutor Schooling Needed! [Re: KnuckleDuster] #1655026
08/08/14 10:22 PM
08/08/14 10:22 PM
Here is what I have to work with, One electronic with the tag appears factory 72 but didn't run the numbers...should I just clean it up
A option would be to purchase a new Autozone rebuilt point dist (reportedly they are cheap) exchange for one of your point ones (P needs a tight dist) then a Pertronix conversion or the electronic dist in the pic. I'm thinking it is a "Prestolite" from the shape of the can & if it functions the same/as well as any other 70's OE electronic dist (anyone?) & if so I would strip it down all the way & solvent clean all the parts ex the can and the pickup & weld up the slots & file em down once you get your initial finalized. Most electronic dists have radial play within limits as the magnetic pull is nowhere near the strength of the point set flat spring & doesn't wear the bushing like the cam opening the points does on the earlier ones. Reduce the axial play to .005 with shims under the lower collar that has the roll pin. www.speedwaymotors.com has a shim kit for cheap. Check/correct rotor phasing as needed. set the reluctor gap at .008" at the tightest point which varies according to the amt of vac adv. NAPA has a .060" longer blade rotor for $8 & change out the door "MO3000". Add the 1/2" ID aftermarket collar on the lower shaft and either peen the dist lower tang or weld up the slot in the intergear to reduce rotational play (turn rotor lightly back & forth by hand & see how much slop you have). Nacho bent the magnet to get nearly zero reluctor gap change from the vac adv but I ain't got around to doing it yet but it's beneficial. Tune the 4 subsystems: initial/total/springs/can IN ORDER. Decide what coil/ballast you wanna run
Re: MP Distrubutor Schooling Needed! [Re: can.al] #1655027
09/07/14 01:17 PM
09/07/14 01:17 PM
North Austin
North Austin
..just sayin'
From which kit? Gonna try this until I get another distrubutor.
Thanks!
Re: MP Distrubutor Schooling Needed! [Re: KnuckleDuster] #1655028
09/07/14 01:31 PM
09/07/14 01:31 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
This is a helpful thread interesting thread.
Maybe a candidate soon for archives?
My question, I have a SB Distributor with two pick ups, one 2 wire and one 3, why is that?
Re: MP Distrubutor Schooling Needed! [Re: KnuckleDuster] #1655029
09/07/14 01:56 PM
09/07/14 01:56 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
Mallory kit pn 29014
i checked my records and my last combo was actually purple and brown.
the purple spring is loose and your curve will be quick until about
half way through when the purple spring adds resistance.
my current curve (vac adv disconnected)
initial 12
1000 16
1600 26
1800 29
2400 29
2600 32
2800 35
...this is on a 9.4:1 340 and seems to run good now.Prior to trying the heavier spring combinations the car would be fine when pushed and the next time it was pushed it would detonate badly.Very irregular as Rick says.hope this helps.
Re: MP Distrubutor Schooling Needed! [Re: can.al] #1655030
09/07/14 03:32 PM
09/07/14 03:32 PM
North Austin
North Austin
Thanks so much for the detailed info!
