Where should I get a replacement starter for my 318 #1654499
08/03/14 04:23 PM
08/03/14 04:23 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
I believe its the original started and she is having trouble cranking the engine over. I do not need anything fancy. Where should I get a replacement?
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Where should I get a replacement starter for my 318 [Re: 68 Sat] #1654500
08/03/14 04:29 PM
08/03/14 04:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Local parts store. Get a mini if you can. They are easier to install and turn the engine over faster.
Re: Where should I get a replacement starter for my 318 [Re: stumpy] #1654501
08/03/14 04:33 PM
08/03/14 04:33 PM
SE PA
Yellow Fever Offline
SE PA
I second that but check rockauto if you don't need it today. Make sure the battery is good too.
Re: Where should I get a replacement starter for my 318 [Re: Yellow Fever] #1654502
08/03/14 04:36 PM
08/03/14 04:36 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
thanks,
It's a 2 year old battery..she just cranks real slow and sounds like she is struggling to turn her over..
Re: Where should I get a replacement starter for my 318 [Re: 68 Sat] #1654503
08/03/14 04:57 PM
08/03/14 04:57 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
thanks,
slow cranking is not really a symptom of a 'dying' starter. get the battery checked and check your starter connections. if the car isn't used much that's where i'd be looking.
Re: Where should I get a replacement starter for my 318 [Re: mikemee1331] #1654504
08/03/14 05:20 PM
08/03/14 05:20 PM
X2 what Mike said. slo charge the batt up & have it load tested and clean all the large cable connections/terminals including the ground path starting with the batt terminals/posts
Re: Where should I get a replacement starter for my 318 [Re: RapidRobert] #1654505
08/03/14 11:31 PM
08/03/14 11:31 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
ok I will try this first...thanks guys
Re: Where should I get a replacement starter for my 318 [Re: 68 Sat] #1654506
08/04/14 01:13 AM
08/04/14 01:13 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Ive had pretty good luck with Autozone rebulit stock starters, and they are pretty cheap to boot.
My buddy just bought a Mopar mini starter for his Jeep from Rock auto, it was new, not rebuilt and under $70
