WATER PUMP CHANGE ON A 98 CARAVAN===3.3 #165419
12/10/08 01:33 PM
12/10/08 01:33 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
I need to change ours as it's seeping, and we're traveling before Christmas, how much of a job is this?
I did one years ago on a 3.3 Dynasty, don't recall it being too hard. Is there much difference from a Dyn. to Caravan?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: WATER PUMP CHANGE ON A 98 CARAVAN===3.3 [Re: Magnumguy] #165420
12/10/08 02:10 PM
12/10/08 02:10 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
same location and operation as the dynasty
piece of cake
Re: WATER PUMP CHANGE ON A 98 CARAVAN===3.3 [Re: gtx6970] #165421
12/10/08 03:30 PM
12/10/08 03:30 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
piece of cake
I used to make alot of easy money on those.....
Re: WATER PUMP CHANGE ON A 98 CARAVAN===3.3 [Re: Magnumguy] #165422
12/10/08 04:32 PM
12/10/08 04:32 PM
S.E.Ohio
S.E.Ohio
That's what I want to hear!!!!
Re: WATER PUMP CHANGE ON A 98 CARAVAN===3.3 [Re: Magnumguy] #165423
12/11/08 02:56 PM
12/11/08 02:56 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Just use caution in removing those 6x1.0 bolts as I have seen those electosize themselves and break off without much effort.
Re: WATER PUMP CHANGE ON A 98 CARAVAN===3.3 [Re: RemCharger] #165424
12/11/08 02:58 PM
12/11/08 02:58 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
piece of cake
I'll bet you didn't make the same amount on a 3.0!
Re: WATER PUMP CHANGE ON A 98 CARAVAN===3.3 [Re: 62maxwgn] #165425
12/14/08 10:09 PM
12/14/08 10:09 PM
Chantilly, VA
foxe Offline
super gas
foxe  Offline
super gas
Chantilly, VA
Remove the passenger side tire and inner fender and it is right there. I didn't have any problem with the bolts, but coated the thread with anti-seize when I put in the new pump.
My water pump went out all at once. One minute I am driving along just fine, the next the bearing went out and threw the serpentine belt off.
Re: WATER PUMP CHANGE ON A 98 CARAVAN===3.3 [Re: foxe] #165426
12/14/08 10:49 PM
12/14/08 10:49 PM
S.E.Ohio
S.E.Ohio
Well, the tensioner had to be changed also, it was about toast.
Went pretty well actually.
