I have a bunch of misc parts I'm thinking of throwing together. A 383, 0.030" over that has old sealed power forged low compression pistons, and not alot of miles on the engine, the B1 B/S heads, a old Crower Compu-Pro cam (I think it is around
220@0.050 duration with a 112 LSA, and maybe 0.500" lift?)
I'd like to use E-85 for fuel, but race gas would be fine. I'd like to run at least 14 lbs of boost, but it's easy to get greedy with boost. The induction will likely be a single plane intake with EFI. I haven't sized any turbos yet, just curious if I will have to change valves and valve seats in the heads I have?
Any input is welcome as this would be the first turbo (gas) engine for me.
