Re: 1965 dodge ??
[Re: Andrewh]
#165401
12/10/08 04:18 PM
12/10/08 04:18 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Well I can tell you plymouth frt hangers and later springs wont work.I know tried to use a set on my 65 and they wont work unless you change the spring position and ther isnt enough room on the stock hanger to redrill it.Rocky
Chrysler Firepower
Re: 1965 dodge ??
[Re: therocks]
#165402
12/10/08 06:09 PM
12/10/08 06:09 PM
Posts: 3,916 usa
lewtot184
usa
after reading your reply i went out to the garage and checked a '64 plymouth hanger against my origanal '65s that were redrilled for 22" front segment xhd spring. the plymouth front hanger is a perfect fit for the later 22" front segment springs.
Re: 1965 dodge ??
[Re: ChevyTS]
#165409
12/10/08 08:28 PM
12/10/08 08:28 PM
Posts: 31,027 Oregon
AndyF
Mancini Racing has the correct spring hangers for early B body cars. You can run 21 inch springs on those cars or change over A body springs or E body springs. You just have to buy the correct hangers to do the trick.
For a street car a good way to go is to use E body replacement springs with the right hangers. For a race car, go with the one inch longer hangers and put Super Stock springs on there.
If you go the E body spring route then the guys at Firm Feel are the ones to call. They are the ones who recommend E body springs on the early B body cars for street performance use.
Re: 1965 dodge ??
[Re: AndyF]
#165411
12/10/08 09:28 PM
12/10/08 09:28 PM
Posts: 576 Texas
ChevyTS
Texas
are you talking about the rear hangers?
Re: 1965 dodge ??
[Re: coro500net]
#165412
12/10/08 10:37 PM
12/10/08 10:37 PM
AndyF
I put ss springs on my 65 coronet,I bolted them in with the stock front hangers,works perfect.
Sure, works perfect if you ignore the one inch change in wheelbase, shorter driveshaft and mis-alignment on the shock absorbers!
Re: 1965 dodge ??
[Re: AndyF]
#165413
12/11/08 09:50 AM
12/11/08 09:50 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
If you need the correct SS spring hangars for a '65 "B" body, PM me. I have a pair that I used for mockup purposes when I moved my springs in. They have never been used.
This is the land of the free
because of the brave
Re: 1965 dodge ??
[Re: AndyF]
#165414
12/11/08 10:25 AM
12/11/08 10:25 AM
Posts: 3,916 usa
lewtot184
usa
Re: 1965 dodge ??
[Re: Pentastar440]
#165415
12/11/08 12:51 PM
12/11/08 12:51 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
The biggest reason to change the K-member is that '68 up has an improved idler arm support bracket. The newer style supports the idler arm at top and bottom with a bolt through the center. The older style is only supported at the bottom.
not to mention that it opens up a huge selection of headers since you would use '66-up headers, better weight distribution and more room for clutch fan/electric fan.
Re: 1965 dodge ??
[Re: rbstroker]
#165416
12/11/08 01:15 PM
12/11/08 01:15 PM
Posts: 576 Texas
ChevyTS
Texas
I guess you are talking about rear hangers because my car has a relocation kit. There are no hanger in the front right?
