E-Body Blower - No AC - Who sells or rebuilds? #1653842
08/01/14 05:21 PM
08/01/14 05:21 PM
Georgia
Steve Bryant Offline OP
Georgia
Sorry for all the questions today. A few google searches are coming up empty for blower motor replacements. I have my heater box taken apart and am working to clean, patch and coat it but my fan motor is dead and it rattles like it's full of BB's.
I have seen some used ones on Ebay that SAY they work but there has got to be a better way!
-Steve
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653843
08/01/14 05:22 PM
08/01/14 05:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just for fun have you tried NAPA?
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: stumpy] #1653844
08/01/14 05:37 PM
08/01/14 05:37 PM
Georgia
Georgia
The one NAPA has is for use with AC and it has a different mounting plate. They have another version but the shaft goes all the way through the motor.
That would be awesome if a local parts store had one that would fit!
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653845
08/01/14 05:47 PM
08/01/14 05:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Can't swap mounting plates?
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: stumpy] #1653846
08/01/14 06:08 PM
08/01/14 06:08 PM
Georgia
Georgia
Well, its that plus the fact that the wires are coming out of the wrong place. The wires on the E-Body exit the motor housing near the shaft side whereas the after-market ones come out the side that will be in the engine compartment. Without opening up the new motor, I would not know if there is a channel inside to re-route the wires.
Even if I removed the plate, the E-Body motor attaches to the heater box by two screws on the motor itself so it uses no plate. This means the motor would have no way to connect to the heater box.
Could I get a new motor and put it into the old motor case? Maybe
Could I drill holes in the heater box plate and install the new motor into it? Maybe
Could I re-route or hide the wires so it would not look obvious from the engine compartment that I used the wrong part? Maybe.
If these are the only choices I have then I may consider them but I was hoping someone sells or rebuilds these so I can put it back the way the factory left it.
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653847
08/01/14 06:35 PM
08/01/14 06:35 PM
Georgia
Georgia
Here is a comparison. I just don't think I could get this to work and have it look right.
My bet is there is a motor out there similar enough to work but I will have to figure it out. The requirements are some way to bolt the motor onto a plate, wires that exit on the same side of the shaft and a sealed housing to keep water, oil, etc out of the motor.
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653848
08/01/14 07:29 PM
08/01/14 07:29 PM
BDW Offline
BDW  Offline
One on the left is right.
Opening is triangular.
Been a couple of yrs, but I got mine from Advanced Auto
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: BDW] #1653849
08/01/14 07:32 PM
08/01/14 07:32 PM
Georgia
Georgia
The one on the left is not right for my car. The one on the right is the original motor.
Still, I can MAKE the one on the left to work if I am willing to drill some holes in the heater box plate, dangle some wires in the engine compartment and cover the motor cover holes with something rigid
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653850
08/01/14 08:32 PM
08/01/14 08:32 PM
Georgia
Georgia
May have a winner here. Four Seasons/Trumark 35504 Blower Motor without Wheel was used on quite a few Mopars including a 1980 Dodge B-300. RockAuto.com let me blast through various Mopars until I found something close. Amazon had this for $27 and it will be here Sunday. If the holes line up, I will tape it off good and blast and coat it.
Will check in again next week in case anyone is interested.
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653851
08/01/14 10:55 PM
08/01/14 10:55 PM
BDW Offline
BDW  Offline
Ok, thought you had original AC car
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653852
08/01/14 11:04 PM
08/01/14 11:04 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
That's the stuff.
I wouldn't be shy about busting out the grinder and knocking those ears off, mig up the gap left behind (if the case wants to open), and grind 'er flush.
Mo' Farts
Moderated by "tbagger".
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653853
08/03/14 05:08 PM
08/03/14 05:08 PM
Georgia
Georgia
It's not perfect but its close enough for now. The new one has a slightly different back but it is sealed and the wires are hidden underneath so they are not in-your-face.
This was the only steel-like paint I had but it's close enough for now. Once I get the box fully assembled, I will run the fan again to make sure it is running in the right direction!
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653854
08/03/14 06:58 PM
08/03/14 06:58 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
THAT is pretty sweet! I wonder what else that motor would fit ? thanks for sharing your end result. we don't get enough of that!
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: mikemee1331] #1653855
08/05/14 10:43 PM
08/05/14 10:43 PM
Georgia
Georgia
Everything is bolted up and working again. I will connect some water lines up later. One thing I noticed is the older fan styles are weak aren't they? I mean it blows air and in the winter with windows closed I am sure it will do fine but it just doesn't compare to modern cars does it?
Either this motor is weak or I have just gotten spoiled with today's jet blowers.
Re: E-Body Blower - No AC - Who sells or rebuilds? [Re: Steve Bryant] #1653856
08/05/14 11:56 PM
08/05/14 11:56 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Have not found an aftermarket one that works as well as the originals did. I am on my fourth one now in 20 years ni the Cuda
