830 hp small block
#1653583
07/31/14 07:56 PM
07/31/14 07:56 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
830 hp small block.im trying to get an idea on how fast it will go in good air. 2950lb-dart.and will i need parachute. the car is going in for some work.to update some things so i was just wondering. what do you guys think.This car with 600hp has been 135mph
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: 830 hp small block
[Re: WHITEDART]
#1653584
07/31/14 08:18 PM
07/31/14 08:18 PM
Triple Threat
Renton Washington
Should be enough to tickle the 150 mark. A parachute is going to be a good idea regardless with that much power / speed. A friends 8 second car broke a brake line last week, he was able to pull the chute and get the car stopped before anything bad happened. Without the chute I bet the car would have been a total loss. Cheap insurance
[Re: Triple Threat]
#1653585
07/31/14 08:23 PM
07/31/14 08:23 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
Yep.... Should go 8.90's at 150+ if it making a true 830 at that race weight.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1653587
07/31/14 09:31 PM
07/31/14 09:31 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I went 8.94@ 151 with 850 hp (corrected) at 3000#. That was a personal best with good air and a hooking track. More average was 9.oh's at 149ish. If your chassis is working a high 8 or 9.oh is in reach.
