Vacuum pump #1653546
07/31/14 05:35 PM
07/31/14 05:35 PM
Ontario,Canada
1967GTX440 Offline OP
Ontario,Canada
I have to put a vacuum pump on my GTX. Any suggestion who be appreciated on which is the best I am looking for something compacted I would like to install it under the hood I think there enough room under the battery box.
Thanks in advance.
Re: Vacuum pump [Re: 1967GTX440] #1653547
07/31/14 05:53 PM
07/31/14 05:53 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'll assume it's for power brakes?...if so I've used the SSBC vacuum pump pn#28146, any pump is going to an eye sore under the hood...I've mounted them inside the drivers front fender behind the headlight area, and brought the lines in under the battery tray for a clean appearance, be sure to rubber isolate it as much as possible as they can be rather noisy ...expect to spend approx. $250-$350 for a quality pump
Mike
Re: Vacuum pump [Re: DAYCLONA] #1653548
07/31/14 10:17 PM
07/31/14 10:17 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Late model minivans have them from the factory, a trip to the bone yard may get you one cheap.
Re: Vacuum pump [Re: DAYCLONA] #1653549
08/01/14 12:44 AM
08/01/14 12:44 AM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
Mike
I have the same SSBC pump on the road runner. So for so good!
I have photos of it if you want to see some?
Re: Vacuum pump [Re: 1967GTX440] #1653550
08/01/14 01:10 AM
08/01/14 01:10 AM
New Mexico, USA
attaboy Offline
attaboy  Offline
New Mexico, USA
I have a George S. Thompson vac pump to run everything except the power brakes on my 71 B body. I mounted it on rubber isolators under the battery tray. It's unseen and works just fine. It runs all my HVAC system. It's controlled by a micro switch that I built into the stock dash controls.
attaboy
Re: Vacuum pump [Re: 1967GTX440] #1653551
08/01/14 10:01 PM
08/01/14 10:01 PM
MidPenMopar Offline
MidPenMopar  Offline
Heres a link to some photos of my SSBC pump in the road runner.
http://www.megahosted.com/gallery/album824
