Re: 5 speed auto in a 71 dart 318
[Re: Slipknot440]
#1653153
07/30/14 11:49 PM
07/30/14 11:49 PM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
a 545FE from a 5.7 Hemi is about the only bolt in option you have without doing adapter plates. A 545RFE is a "5 speed" tranny, but not how you would think. It has 2 second gears, one for upshifting and another that is between 2nd and 3rds ratio for passing gear when it shifts down. You would also need a computer to run this trans and extensive floor modifications. As for a regular 5 speed auto, I think you are SOL. The gear vendors unit replaces the tail shaft and gives you more overdrive gears.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
