AMP gauge running high charge?? #1653054
07/30/14 02:29 PM
07/30/14 02:29 PM
Alberta Canada
LuvEBodies Offline OP
Alberta Canada
I was hoping someone here could steer me in the right direction. My amp gauge just started running high. I noticed it when my dash lights got brighter. When I drop the the engine RPM the gauge drops, rev up gauge goes up. What should I check first. Any help would be appreciated.
Re: AMP gauge running high charge?? [Re: LuvEBodies] #1653055
07/30/14 02:33 PM
07/30/14 02:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have the battery checked.
Re: AMP gauge running high charge?? [Re: stumpy] #1653056
07/30/14 02:38 PM
07/30/14 02:38 PM
Alberta Canada
Alberta Canada
Ok, I'll try another battery, I just check the voltage with my multimeter, 17v at high idle. could it be the voltage regulator or would it be the alternator?
Re: AMP gauge running high charge?? [Re: LuvEBodies] #1653057
07/30/14 04:38 PM
07/30/14 04:38 PM
P
Paul_Fancsali Offline
P
Regulator is bad !
Re: AMP gauge running high charge?? [Re: LuvEBodies] #1653058
07/30/14 04:52 PM
07/30/14 04:52 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Double check your alternator and regulator wire connections. Also make sure the regulator is securely grounded..
Just my $0.03...
Re: AMP gauge running high charge?? [Re: Sinitro] #1653059
07/30/14 05:03 PM
07/30/14 05:03 PM
very likely the reg itself. way less likely would be alt/brushes & unplug the green field wire at the alt (later type 2 field wire system) & if it stops charging then it ain't the alt/brushes. If it's an early "box" reg it could have lost it's ground continuity but fairly rare. unplug the reg triangle connector till you get it taken care of as that full fielding (17+ volts) will cause multiple problems quickly
Re: AMP gauge running high charge?? [Re: LuvEBodies] #1653060
07/30/14 05:31 PM
07/30/14 05:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What year? Single or dual field connectors?
Re: AMP gauge running high charge?? [Re: John_Kunkel] #1653061
07/30/14 08:09 PM
07/30/14 08:09 PM
Alberta Canada
Alberta Canada
I switched regulators, steady at 14.7v.
Thanks for all the help guys.
