Re: What would be best for my truck
[Re: 76dodgeboy]
#1652937
07/30/14 01:33 PM
07/30/14 01:33 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
5" stacks. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: basketcase]
#1652941
07/30/14 06:29 PM
07/30/14 06:29 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
I always liked the sound of duals with just some cheaper bottle style mufflers on it. I like to bring them out in front of the read tires as well. [/quote)
Yep.....I agree as well unless it's an all out performance goal......I'd stick with 2-2 1/2" with some Purple Hornies.....sounded awesome on my sons truck and the whole shoot'n match was 100 bucks out the door plus my labor which is normally an 18 pack of miller lite ![](/ubbthreads/images/graemlins/wink.gif)
Rickster
[Re: BulletBob]
#1652942
07/30/14 09:40 PM
07/30/14 09:40 PM
Posts: 5,965 Greenville, PA
redraptor
Greenville, PA
You'll build more toque using a single 3" & will be cheaper to have done also
I disagree. 2" duals would be cheaper and flow enough. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: redraptor]
#1652944
07/30/14 10:05 PM
07/30/14 10:05 PM
rickstershemi
![](/ubbthreads/images/graemlins/iagree.gif)
Rickster
[Re: BulletBob]
#1652950
07/31/14 08:56 PM
07/31/14 08:56 PM
rickstershemi
Duals for $100 there's 2 1/2 sticks in duals on a Dodge truck Cheap aluminized sells for around $35 a stick & the mufflers at cost are $15 each ^ hangers minimum at $2 each It takes a good muffler guy 3-4 hours to do that 4wd the right way from the manifolds back
I used to do exhaust
Well Bob that's all mine cost....did the install myself....mine went from header collectors to mufflers and downturned right at the rear axle....fuel cell in the bed. See it can be done....maybe next time ask first how it was done ![](/ubbthreads/images/graemlins/wave.gif)
Good Ole Moparts ![](/ubbthreads/images/graemlins/wink.gif)
Rickster
[Re: roe]
#1652952
08/01/14 09:54 AM
08/01/14 09:54 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Well I specified the size I plan to use. 2" is too small to me. Maybe for a smallblock but not a 440. Its not a Diesel or a Stepside so no stacks either. Single 3" will actually cost more and I plan on doing it myself. Dual would exit before both rear tires(as it is already) Single 3' would utilize the Factory tailpipe available(have one on my 75 D100)
Is this for the truck you painted green with the roller? If so can you post a current pic? I'm hoping to put on coats 3 & 4 on my truck this wknd.
No clue what your talking about ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: BulletBob]
#1652953
08/01/14 10:41 AM
08/01/14 10:41 AM
rickstershemi
headers to the axle can be done for $100 like that but not on a 4wd Maybe you should have been more clear
Two basically straight pieces of pipe with mufflers is hardly what a 4WD requires
Guess I'm just lucky having a friend with a exhaust pipe machine that doesn't cost me anything. I shop around auto parts stores and have found many bargains on returns (mufflers) that typically I can pick up for a song.
My point is you can do it very inexpensively if you take your time and do it yourself....I try to do everything myself, I enjoy it....but that's just me.
Last set of Welded Turbo 2 1/2" mufflers cost me $15.00 ea.(returns) Auto Zone ![](/ubbthreads/images/graemlins/Twocents.gif)
Rickster
