Re: Any way to replace the steering column joint?
[Re: B5 Bee]
#1652658
07/31/14 09:31 AM
07/31/14 09:31 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
The problem with these universal joints are they don't allow for chassis flex like the OEM coupler does.
could you explain this? i'm trying to visualize why not but I can't. is there a lack of forward/backward travel?
[Re: NachoRT74]
#1652665
07/31/14 04:17 PM
07/31/14 04:17 PM
mikemee1331
bethlehem pa
yes there is... the unibody frame design gets lots of flex between frame rail and cab ( have you tried to open the door when the car jacked up? ), and shaft is a piece in the middle of both body sections.
only way to half accept this universal fixed steering coupler is using frame rail connectors ( and still will need to be checked)
Thanks Nacho! hope all is well!
[Re: Supercuda]
#1652666
07/31/14 05:19 PM
07/31/14 05:19 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Borgeson has a solution, they list it for Dodge trucks but they may custom make them
https://www.borgeson.com/xcart/popup_image.php?type=D&id=1452
would be the same than break the safety shaft plastic pins into the column shaft
Not sure what you are saying here. The Borgeson unit allows for the joint to slide in and out some.
Nothing wrong with the Borgeson unit you linked to. The one Cudajon posted a pic of will lead to problems.
[Re: 71sat440]
#1652667
07/31/14 05:28 PM
07/31/14 05:28 PM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
I got one of those aftermarket shafts off of a 1990 w250 at a junkyard. I used it to build the shaft on my newport when I put a manual steering box in. It has long splines to let it slide into the ujoint. Lots of steering joints at junkyards that are the same spline, way cheaper too. [image] [/image]
[Re: NachoRT74]
#1652669
07/31/14 09:27 PM
07/31/14 09:27 PM
Posts: 4,724 Florida
BDW
I agree with above, the firm feel coupler and removing the safety plugs will allow the shaft to slide if needed.
Why spend extra for the whole deal?
