62 Plymouth horn location ??? #1652639
07/29/14 09:44 PM
07/29/14 09:44 PM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
I haven't done much with my car for a couple years now. Just burned out a bit I guess. Now I've started back and I was going to install my horns but I can't remember where they went. I can't find the two holes that would indicate the original location. Can anyone help out with a photo or suggestion ? Thanks
Re: 62 Plymouth horn location ??? [Re: 62440] #1652640
07/29/14 10:32 PM
07/29/14 10:32 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
The horns mount on the passenger side on the rear of the core support next to the radiator.
Re: 62 Plymouth horn location ??? [Re: TooMany62s] #1652641
07/29/14 11:44 PM
07/29/14 11:44 PM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
That's maybe why I couldn't find the holes. It's got a aluminum rad and a catch can on the drivers side. I guess I'll have to tuck them in somewhere else. Are they supposed to be pointed down or facing the front ?
Re: 62 Plymouth horn location ??? [Re: 62440] #1652642
07/30/14 01:59 AM
07/30/14 01:59 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Like this.
Re: 62 Plymouth horn location ??? [Re: 62maxwgn] #1652643
07/30/14 03:28 AM
07/30/14 03:28 AM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
Thanks Bill. Just what I needed.
Re: 62 Plymouth horn location ??? [Re: 62440] #1652644
07/30/14 11:33 AM
07/30/14 11:33 AM
Andrewh Offline
Andrewh  Offline
on my 65 I added a bigger rad and had no room for them.
I put them on the other side of the core support. it is tight to get your arm in there, but they fit on that side and can be bolted up.
I decided not to add more wire length though, and could only get one to wire up.
