Page 1 of 3 1 2 3
N/A cam for my engine to run N/A #1652387
07/29/14 09:57 AM
07/29/14 09:57 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My Victors flow 350 at .600,10.5 cr 446" 3.75 stroke,6800 rpm.I know my gearing is not correct or my convertor but wehen looking at alternatives you have to start somewhere.THX!
PS:I want a roller cam.
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652388
07/29/14 10:25 AM
07/29/14 10:25 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mike,are you taking the blower off????????????????????
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: N/A cam for my engine to run N/A [Re: hemi-itis] #1652389
07/29/14 10:59 AM
07/29/14 10:59 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Not for good just a change of pace.
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652390
07/29/14 11:31 AM
07/29/14 11:31 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I think I may be able to advance my cam and use it but I don't know.OI have been told it is like an old Super stock cam but like I said I have no idea.
.646 int .631 exh
at .050 260 int 269 exh
at .020 291 int 306 exh
int open 21 close at 59
exh open 69 close at 19
112 LSA
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652391
07/29/14 12:07 PM
07/29/14 12:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Where do the heads peak at? This is one of the reasons I love n/a............WAY easier for my dumb azz to go fairly fast and still beat power adder cars.
Re: N/A cam for my engine to run N/A [Re: Thumperdart] #1652392
07/29/14 12:12 PM
07/29/14 12:12 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I went to boost cuz I could not build a N/A engine.
The heads peak at .650 at 355 cfm
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652393
07/29/14 12:58 PM
07/29/14 12:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Comp makes a .680 thats a good cam!
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652394
07/29/14 01:18 PM
07/29/14 01:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My Isky gring could work although you`re a bit heavy.........
Re: N/A cam for my engine to run N/A [Re: FastmOp] #1652395
07/29/14 01:23 PM
07/29/14 01:23 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I want to stay below .650 to stay away from any bind even tho I have about .200 at .650
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652396
07/29/14 01:24 PM
07/29/14 01:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The closer to coil bind the better.............
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652397
07/29/14 02:03 PM
07/29/14 02:03 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Looking at comp cams page I think my cam is better with more lift shorter dur and 2* more LSA for avg hp.
Re: N/A cam for my engine to run N/A [Re: Thumperdart] #1652398
07/29/14 02:13 PM
07/29/14 02:13 PM
ohio
all spooled up Offline
ohio
get a hold of Dwayne porter
Re: N/A cam for my engine to run N/A [Re: all spooled up] #1652399
07/29/14 02:18 PM
07/29/14 02:18 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
as much as I would like to pic his brain for info I don'r know if he has the time for someone with a not so serious build[not perfect].
Re: N/A cam for my engine to run N/A [Re: Thumperdart] #1652400
07/29/14 02:23 PM
07/29/14 02:23 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What's the best time slip look like on that Big Bad Blown B-Body?
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652401
07/29/14 02:26 PM
07/29/14 02:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sure he does , he helps me all the time
Re: N/A cam for my engine to run N/A [Re: FastmOp] #1652402
07/29/14 02:27 PM
07/29/14 02:27 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
6.50 109 mph in the 1/8 1.44 60'
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652403
07/30/14 09:31 AM
07/30/14 09:31 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
.646 int .631 exh
112 LSA
Any more help on my cam profile?I may run it on the dyno to brake in my new rings.I tried to look up a coouple of victor builds that I know were posted but I could not find them.
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652404
07/30/14 09:36 AM
07/30/14 09:36 AM
tboomer Online work
tboomer  Online Work
Re: N/A cam for my engine to run N/A [Re: tboomer] #1652405
07/30/14 09:57 AM
07/30/14 09:57 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks,A lot of strokers in those builds.
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652406
07/30/14 11:15 PM
07/30/14 11:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Why not check piston to valve clearance at 108* and try the cam you have? Get a baseline and go from there. Plenty of issues going on with your car. Start simple.
Doug
Page 1 of 3 1 2 3
