solid one piece upper control arm bushings? #1652332
07/29/14 02:24 AM
07/29/14 02:24 AM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline OP
anyone here have them? my car had solid bronze bushings in the upper arms when I bought it. I decided not to change them out for poly bushings they really free up the front end.im about to get the front end aligned and wonder if it will cause the car to handle any different.
Re: solid one piece upper control arm bushings? [Re: 64hemi330sedan] #1652333
07/29/14 02:34 AM
07/29/14 02:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If the center bolt is still just a clearance fit
it wont change anything except easier movement..
when I use to put them in I drilled a hole to the
center then put in a zert fitting for grease so they
would live longer
EDIT
I also indexed the bolt hole to allow for more caster
Re: solid one piece upper control arm bushings? [Re: 64hemi330sedan] #1652334
07/29/14 11:56 AM
07/29/14 11:56 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Damn that car is looking awesome
So when and where will the maiden voyage take place? I would love to see it for all the workmanship you put into it
Russ
Re: solid one piece upper control arm bushings? [Re: 64hemi330sedan] #1652335
07/29/14 12:12 PM
07/29/14 12:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I think Calvert makes em.............
