Page 1 of 3 1 2 3
Broken weld on spring perch??? #1652289
07/29/14 01:55 AM
07/29/14 01:55 AM
Great Neck,LI,new york
hemi-itis Offline OP
If the weld broke on the right side spring perch broke, would it cause the car to go right at the hit of the throttle??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652290
07/29/14 02:20 AM
07/29/14 02:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Depends on where it broke and which side of the car
but if the right side is moving forward then it will
turn right
Re: Broken weld on spring perch??? [Re: MR_P_BODY] #1652291
07/29/14 10:34 PM
07/29/14 10:34 PM
That's what I figured Installed new rear shocks and noticed something shiney in the rust
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652292
07/29/14 10:42 PM
07/29/14 10:42 PM
When that gets repaired,will also reweld the other perch and do the axel tubes and front shock mount tabs.
How do you guys brace the tubes to the perch??
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652293
07/29/14 10:46 PM
07/29/14 10:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats because all the weld is on the bracket and zero penetration on the tube
Re: Broken weld on spring perch??? [Re: Quicktree] #1652294
07/29/14 10:52 PM
07/29/14 10:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep
Re: Broken weld on spring perch??? [Re: Quicktree] #1652295
07/29/14 11:03 PM
07/29/14 11:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s exactly what I was thinking WAY more weld on the bracket...........
Re: Broken weld on spring perch??? [Re: Thumperdart] #1652296
07/29/14 11:16 PM
07/29/14 11:16 PM
Should be able to get on a lift in the next few days.You'll also notice the tubes are not welded to the center,,,,,,,,,,,,,,,,yet. At least I finally put on some DA shocks
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652297
07/29/14 11:17 PM
07/29/14 11:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
did quicknick weld those for you?
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652298
07/29/14 11:21 PM
07/29/14 11:21 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I would also gusset the spring perches into the tubes while your at it
Re: Broken weld on spring perch??? [Re: Quicktree] #1652299
07/29/14 11:21 PM
07/29/14 11:21 PM
LOL No,my welders are HEMICUDA1,SPOOLX & TRICKEYRICKEY
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652300
07/29/14 11:26 PM
07/29/14 11:26 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
As stated, the perches should have gussets to the middle or tops of the tubes.
Re: Broken weld on spring perch??? [Re: topside] #1652301
07/29/14 11:34 PM
07/29/14 11:34 PM
Would that be 4 per side?
Re: Broken weld on spring perch??? [Re: topside] #1652302
07/29/14 11:35 PM
07/29/14 11:35 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
Buy some perches from Calvert racing, super beefy and lots of wrap around tube.
68 Barracuda Formula S 340
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652303
07/29/14 11:39 PM
07/29/14 11:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
2 Per side, 1 front and 1 back of each side of the tube per side. Someone will have some pics.
Re: Broken weld on spring perch??? [Re: Sport440] #1652304
07/29/14 11:45 PM
07/29/14 11:45 PM
Pic's would be great!!
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652305
07/29/14 11:48 PM
07/29/14 11:48 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'd send you some but mine are not boxed in either
Re: Broken weld on spring perch??? [Re: roadhazard] #1652306
07/30/14 12:05 AM
07/30/14 12:05 AM
I'll save the boxing for the next time the rear has to come out.For now will repair existing perch welds,add some type of gusset and weld the tubes
Re: Broken weld on spring perch??? [Re: roadhazard] #1652307
07/30/14 12:06 AM
07/30/14 12:06 AM
Tulsa OK
Tulsa OK
Calvert perches $39
Re: Broken weld on spring perch??? [Re: Bad340fish] #1652308
07/30/14 12:25 AM
07/30/14 12:25 AM
Calvert perches $39
When I replace the perches,this looks like the ticket
Page 1 of 3 1 2 3
