Re: Broken weld on spring perch???
[Re: hemi-itis]
#1652290
07/29/14 02:20 AM
07/29/14 02:20 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If the weld broke on the right side spring perch broke, would it cause the car to go right at the hit of the throttle??
Depends on where it broke and which side of the car but if the right side is moving forward then it will turn right
[Re: hemi-itis]
#1652292
07/29/14 10:42 PM
07/29/14 10:42 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
When that gets repaired,will also reweld the other perch and do the axel tubes and front shock mount tabs. How do you guys brace the tubes to the perch??
[Re: hemi-itis]
#1652293
07/29/14 10:46 PM
07/29/14 10:46 PM
Quicktree
That's what I figured Installed new rear shocks and noticed something shiney in the rust
thats because all the weld is on the bracket and zero penetration on the tube
[Re: Quicktree]
#1652294
07/29/14 10:52 PM
07/29/14 10:52 PM
MR_P_BODY
Yep
[Re: Thumperdart]
#1652296
07/29/14 11:16 PM
07/29/14 11:16 PM
hemi-itis
Should be able to get on a lift in the next few days.You'll also notice the tubes are not welded to the center,,,,,,,,,,,,,,,,yet. At least I finally put on some DA shocks
[Re: topside]
#1652302
07/29/14 11:35 PM
07/29/14 11:35 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Buy some perches from Calvert racing, super beefy and lots of wrap around tube.
68 Barracuda Formula S 340
[Re: hemi-itis]
#1652303
07/29/14 11:39 PM
07/29/14 11:39 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
As stated, the perches should have gussets to the middle or tops of the tubes.
Would that be 4 per side?
2 Per side, 1 front and 1 back of each side of the tube per side. Someone will have some pics.
