poly 318 with LA heads. #1652273
07/29/14 01:02 AM
07/29/14 01:02 AM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
Can you put LA style small block heads on a 318 poly motor?
I was thinking of boring it out to 4.04 and using 915 340 J heads 2.02 1.60 valves.
Any ideas.
Re: poly 318 with LA heads. [Re: kams] #1652274
07/29/14 01:20 AM
07/29/14 01:20 AM
Here and now
jeebis44 Offline
jeebis44  Offline
Here and now
I'm pretty sure the geometry's all wrong on many levels
Re: poly 318 with LA heads. [Re: jeebis44] #1652275
07/29/14 06:22 AM
07/29/14 06:22 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
I think if you lay a LA head gasket on the poly block you will find no way to put intake pushrods in it.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: poly 318 with LA heads. [Re: shinnery] #1652276
07/29/14 10:14 AM
07/29/14 10:14 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree they are different.Rocky
Chrysler Firepower
Re: poly 318 with LA heads. [Re: therocks] #1652277
07/29/14 12:33 PM
07/29/14 12:33 PM
Andrewh Offline
Andrewh  Offline
someone here or maybe another board used to say it would work, but I don't recall actually seeing pictures, or anyone else trying.
Re: poly 318 with LA heads. [Re: therocks] #1652278
07/29/14 12:34 PM
07/29/14 12:34 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I was always told the reason push rod angles suck on an LA is because they never changed the lifter angle from a poly.
Kevin
Re: poly 318 with LA heads. [Re: Twostick] #1652279
07/29/14 02:06 PM
07/29/14 02:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
LAs go on a poly easy enough, it is the other way around you don't want ot get involved in
They have the same deck height, rods, crank, pistons, timing cover, timing set, lifter angle, oil pump... just the poly block has clearance for the intake PR to go at a weird angle and the LA does not, if you try to notch you LA block for poly PR angles you will hit water.
Re: poly 318 with LA heads. [Re: Twostick] #1652280
07/29/14 09:26 PM
07/29/14 09:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Kevin
Correct, Chrysler was saving a dime from retooling. The pushrod angle was designed for the polyhead and they needed a smaller v8 package for the new a-bodys so a smaller head was designed for the block they had. The block had proven to be very good, all about money. I think the poly head would have been a better perfprmance head in the long run(canted valves).
Re: poly 318 with LA heads. [Re: cudaman1969] #1652281
07/29/14 09:42 PM
07/29/14 09:42 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
Don't forget to use an LA camshaft, as the valve layout on the LA heads is different than on the poly. Regards, Chase
Re: poly 318 with LA heads. [Re: kams] #1652282
07/29/14 09:55 PM
07/29/14 09:55 PM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
I just want to use the poly block so I can bore it out to a 340 size and make a cheap motor.
Re: poly 318 with LA heads. [Re: kams] #1652283
07/29/14 11:12 PM
07/29/14 11:12 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Are you sure that the Poly 318 3.91 bore can go .130 to a 4.04 bore...?
Tony
70 AARCuda Vitamin C
Re: poly 318 with LA heads. [Re: 70AARcuda] #1652284
07/30/14 02:19 PM
07/30/14 02:19 PM
dogdays Offline
dogdays  Offline
UT is your friend. There is no guarantee that any 3.91 block will go to 4.040.
Yes, the LA (Light A) block is lighter than the Poly, but where did the weight change come from? Hasn't been researched, AFAIK. Mopar castings were all over the map, early or late.
R.
Re: poly 318 with LA heads. [Re: dogdays] #1652285
07/30/14 02:48 PM
07/30/14 02:48 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They were way thicker in general but core shift was worse so the odds are better but still not good, especially considering 60 years of corrosion from not being serviced properly...
BTW I have a 71 318 block in the shop right now that is 4.070 bored and was a running motor with 12.5 compression, no block filler and was being dirt track raced till it developed a rod knock... I am scared to reassemble it
Re: poly 318 with LA heads. [Re: HotRodDave] #1652286
07/30/14 03:28 PM
07/30/14 03:28 PM
dogdays Offline
dogdays  Offline
It'd be interesting to sonic check it.
R.
Re: poly 318 with LA heads. [Re: dogdays] #1652287
07/30/14 03:53 PM
07/30/14 03:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I sonic tested it by tapping the bores with a screw driver and they sound like glass, the block weighs 122# and a 68 std bore block (same casting number) weighs 165# on the same scale
Re: poly 318 with LA heads. [Re: HotRodDave] #1652288
07/30/14 07:51 PM
07/30/14 07:51 PM
dogdays Offline
dogdays  Offline
43 lb is 43 / 0.258 = 167 cubic inches of material. Calculating a 6" high cylinder 4.040 inches diameter, subtracting a 3.91" cylinder 6" high I get around 48 cubic inches, so your numbers work out.
I bet you don't have any cylinder wall with more than 0.100" thickness.
R.
