How many miles a year on your roller cam motor? #1652204
07/28/14 10:51 PM
07/28/14 10:51 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Real street miles, not just putts around town. But im not talking interstate either. Somwhere in between..And what is your setup? How agressive of a lobe? Spring pressures?
Re: How many miles a year on your roller cam motor? [Re: Hot 340] #1652205
07/29/14 02:06 AM
07/29/14 02:06 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
9500 miles in two years. includes two Hot Rod Drag Weeks, round trip from Phx. to Vegas, many trips to work and back and just driving around on weekends.
Still going strong. Solid roller, 200 on the seat, 500 open.
Also over 60 1/4 mile passes.
Re: How many miles a year on your roller cam motor? [Re: Hot 340] #1652206
07/29/14 02:29 AM
07/29/14 02:29 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Lift, duration and even spring pressure is NOT what kills cams on the street. It is how aggressive the lobe is. IE, how fast it opens and closes the valve. A VERY aggressive ramp speed on a lobe will murder a valvetrain in short order on the street. Keep the lifter ON the cam and you will be fine. Ultra fast "closing ramps" where the cam basically falls out from under the lifter will munch parts.
Monte
Re: How many miles a year on your roller cam motor? [Re: Monte_Smith] #1652207
07/29/14 03:17 AM
07/29/14 03:17 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Non aggressive lobed Isky solid roller here w/.680-.660 lift and 275-280 dur.@ .050 and for the first several years I ran 200-210 seat pressures and clipped into the 9`s and drove it everywhere here in the desert and even over an hour to L.A. w/out any issues. I rebuilt the rollers a few years ago, upped the seat #`s to 230-235 and still going strong. No power tour or cross country stuff like some but now a solid 9 second n/a car that doesn`t over heat or load up and is a blast to drive.
Re: How many miles a year on your roller cam motor? [Re: Monte_Smith] #1652208
07/29/14 03:43 AM
07/29/14 03:43 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Monte
But that is directly related to spring pressures. There is also valve seats and guides and lifters to worry about. And spring pressure will have an effect.
Re: How many miles a year on your roller cam motor? [Re: viperblue72] #1652209
07/29/14 04:13 AM
07/29/14 04:13 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
I can have two cams, with the same lift and duration and also the same seat and over the top pressure.....lets say 300 and 800. With lobe profiles I can make one ultra reliable and the other beat valvetrain parts out as fast as you can change them.
I design some BIG stuff for several Drag Week cars. Lifts approaching 1" and seat pressures of 375. They survive Drag Week just fine. Its all about the ramps
Monte
Re: How many miles a year on your roller cam motor? [Re: Monte_Smith] #1652210
07/29/14 08:01 AM
07/29/14 08:01 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I had Bullet grind me a solid roller and I made sure to stress I wanted some gentle ramps. The cam is .767/.676, 288/292@.050 with 250lbs on the seat and 740 over the nose. After 3 years of street driving it's still going strong with zero issues.Dave
Re: How many miles a year on your roller cam motor? [Re: quickd100] #1652211
07/29/14 09:54 AM
07/29/14 09:54 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am by far no valve train expert but if you see some spintron data its pretty crazy what everything goes through. From Loft from the pushrod flexing to bounce on the return its pretty nuts.
I don't have all my cam specs so I can't tell you how aggresivve the lobe is right now. I have a solid roller 258@.050 and .650 lift with 1.6 rockers on a small block. I don't drive it as much as I like but I put about 5000 miles on my last set of lifters before I pulled them. I am going to send them to comp to be checked out I just haven't gotten around to it. I also change my springs every year before drag week, I haven't tested them or anything I just change them. It makes me feel better when I am buzzing down the highway at 3500RPM for hours at a time.
One thing I have seen on my cam is evidence of bounce on the closing side. You can't feel it with your finger but its there in the shiny markings if you hold the cam in the right light. I noticed that after my first teardown after dragweek in 2012. I just had the top end off of the motor to put new lifters in and I couldn't see those marks anymore but the cam was still in the motor. The only thing I did change was the lash. I went from running it off the mopar sticker to ICEO or whatever the order is(I have to look everytime LOL) same lash settings but different way of running the valves and the valvetrain sounds way better. Using the same lash with the mopar method my car sounded like a duramax after a few hours on the highway, the other method it sounds "normal" especially considering the lash has to grow a good amount with several hours of heat soak in all the parts.
68 Barracuda Formula S 340
Re: How many miles a year on your roller cam motor? [Re: Darryls-Demon] #1652212
07/29/14 07:15 PM
07/29/14 07:15 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Darryl, what are your cam specs?
Re: How many miles a year on your roller cam motor? [Re: Monte_Smith] #1652213
07/29/14 07:19 PM
07/29/14 07:19 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Monte
Monte
So the big question has been for me, and ive asked this on Yellowbullet with no sucess, is, how do you see or judge an agressive lobe by looking at cam specs? I know its easy to just ask a lobe designer, but I want to know myself.
Re: How many miles a year on your roller cam motor? [Re: Hot 340] #1652214
07/29/14 11:02 PM
07/29/14 11:02 PM
Glendale Az
Glendale Az
.254-.260@.050 .699-.703 lift
Lifters where checked at 5000 miles, they looked new. I do run a very tight lash .010 Intake .011 exhaust
Valve springs have never been changed.
Re: How many miles a year on your roller cam motor? [Re: Darryls-Demon] #1652215
07/29/14 11:12 PM
07/29/14 11:12 PM
Glendale Az
Glendale Az
Also have a solid roller in my Challenger that has 5000 miles on it but no track time.
I have driven this car to Vegas also and up and down the mountains to cottonwood AZ.
This car is fun to drive.
Cam is .248-.254 and .620 lift. 200 on the seat, 500 open.
Re: How many miles a year on your roller cam motor? [Re: Darryls-Demon] #1652216
07/30/14 11:39 AM
07/30/14 11:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I don't get as much driving in as I'd like but I probably do 500-1000 a year. The longest drive I've done is 51 each way to race. 90% is highway on that one. Most of the other driving is around town, up and back to my bros and such. I'm running a small comp cams solid roller (588). I have had any issues. It's been in t he car 3.5 years. I hardly ever touch the adjustors. The Ross pistons make more noise than the cam...lol
Coming soon!!!!
Re: How many miles a year on your roller cam motor? [Re: Hot 340] #1652217
07/30/14 12:17 PM
07/30/14 12:17 PM
Finland
LUMI Offline
LUMI  Offline
Finland
110 gallons this year with new street engine, less than 400 miles from new
328/320deg 288/280 on 0.50
0.70int 0.76ex lift
210 lbs close 620 open
seems to be too much for B1 Originals
