Original 360 vs 5.9 magnum to build
#1652091
07/28/14 03:23 PM
07/28/14 03:23 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
I am thinking that after 70k + miles, and having oil consumption going up, and perhaps a weak cylinder, it is time to look at the E58 360 in my 74 Duster360. It is the original engine, rebuilt 70k+ miles ago, can't recall what went into it, pretty much all stock.
I love to drive this car, long distance, etc . . . so, do you guys think another stock rebuild would be the way to go ?? Or get a 5.9 magnum and rebuild it (maybe even stroked ??) . . . I do like the "go", but also like having a smooth idle and some sort of mpg ! Would also like to keep the exhaust I have on the car - factory manifolds, right side the the Y style off a 340 and left is the 360 factory manifold. Stock 727 and 8.25 rear (still has the 2.45:1 gears - even the tired 360 cranks the tires over !!! And pulls 22mpg at 70mph) . . . . .
Just interested to see what is happening out there these days, and what your thoughts would be. . .
Thanks,
Mark
Re: Original 360 vs 5.9 magnum to build
[Re: a12rag]
#1652093
07/28/14 03:54 PM
07/28/14 03:54 PM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
I would use a late model LA block or Magnum for the next build to be able to use a roller cam. The LA blocks from 89 to 92 I believe had provisions for roller cams and all Magnum motors had them. A roller would give you a nicer idle with a bit more aggressive profile than a comparable flat tappet. Magnums have the added benefit of coming with a superior head.
If you don't plan on going much over 300HP I would keep the factory manifolds for the ease of working on it, ground clearance and quietness. Much over 300HP though and you start to leave a lot on the table without them.
[Re: MarkZ]
#1652095
07/28/14 04:09 PM
07/28/14 04:09 PM
a12rag
Thanks for the input - yes those are mpg for imperial gallon, not US. If I was to stroke out the 5.9 magnum, I would probably look at headers and different exhaust . . . keeping the 5.9 magnum, relatively stock would certainly be better than the LA, I was thinking . . . and of course keep the original engine tucked away . . .
The MPG concern isn't so much for what it gets, rather, how many miles I can go between fill ups, as the Duster has a small tank !!!
[Re: can.al]
#1652100
07/29/14 01:01 AM
07/29/14 01:01 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Heads, intake, pushrods, rockers, cover the requirements. You can redrill the heads to accept an LA intake, someone on Moparts had a jig that got passed around years ago just for this. You may, or may not, need to replace the lifters for oil thru the pushrods, you will have to look and see to know. LA valve covers can work on a Magnum head, just pay attention to fitment as they are not identical. Exhaust manifolds/headers should bolt up for the most part. If you have air injection manifolds you might have an issue there.
[Re: Supercuda]
#2446899
02/05/18 03:40 PM
02/05/18 03:40 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Neither the magnum block, nor the LA block have provisions for a fuel pump.
Incorrect, the LA TBI motors did have a long snout cam with the pump eccentric with a block off plate. This changed on some 318s so you have to check before you buy - later cams used a spacer instead of the eccentric (can just swap out) or went to a cam without the provision. AFAIK the 360s all came with the long snout cam and eccentric up until phase out for the magnums.
[Re: a12rag]
#2446934
02/05/18 04:39 PM
02/05/18 04:39 PM
Supercuda
About to go away
About to go away
up yours
Incorrect, the LA TBI motors did have a long snout cam with the pump eccentric with a block off plate. This changed on some 318s so you have to check before you buy - later cams used a spacer instead of the eccentric (can just swap out) or went to a cam without the provision. AFAIK the 360s all came with the long snout cam and eccentric up until phase out for the magnums. Ah, the old Moparts illiteracy program. Let me clarify for you. Neither the magnum block, nor the LA block have provisions for a fuel pump. As Foghorn Leghorn would say, pay attention son, I say pay attention. Someone in the thread claimed the magnum block had no provisions for a fuel pump. No [censored] sherlock, none of them do, that's not where the fuel pump mounts.
[Re: dogdays]
#2446962
02/05/18 05:45 PM
02/05/18 05:45 PM
Montclaire
Scranton, PA
Count on Montclaire to resurrect a 3 1/2 year old post to give a wrong answer!
R. Who are you again?
[Re: a12rag]
#2447199
02/06/18 12:38 AM
02/06/18 12:38 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
my 88 318 tbi has been converted to carb and mechanical fuel pump..I removed the blocking plate and installed a pump...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
