Original 360 vs 5.9 magnum to build #1652091
07/28/14 03:23 PM
07/28/14 03:23 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
I am thinking that after 70k + miles, and having oil consumption going up, and perhaps a weak cylinder, it is time to look at the E58 360 in my 74 Duster360. It is the original engine, rebuilt 70k+ miles ago, can't recall what went into it, pretty much all stock.
I love to drive this car, long distance, etc . . . so, do you guys think another stock rebuild would be the way to go ?? Or get a 5.9 magnum and rebuild it (maybe even stroked ??) . . . I do like the "go", but also like having a smooth idle and some sort of mpg ! Would also like to keep the exhaust I have on the car - factory manifolds, right side the the Y style off a 340 and left is the 360 factory manifold. Stock 727 and 8.25 rear (still has the 2.45:1 gears - even the tired 360 cranks the tires over !!! And pulls 22mpg at 70mph) . . . . .
Just interested to see what is happening out there these days, and what your thoughts would be. . .
Thanks,
Mark
Re: Original 360 vs 5.9 magnum to build [Re: a12rag] #1652092
07/28/14 03:51 PM
07/28/14 03:51 PM
dogdays Offline
dogdays  Offline
Miles per Imperial gallon?
The Mag engine has a much better combustion chamber, might be worth 3mpg over the typical 360 head.
I'm going out on a limb here, but I'd suggest a 5.2 Mag motor, built correctly. Board members say the built 5.2 Mag and the LA 360 in near-stock form are quite equivalent in terms of acceleration, but the 5.2 increases mpg by something like 5 or 6.
Seeing how you like to drive the car, and it isn't primarily a drag racer, this sounds like the way to go.
R.
Re: Original 360 vs 5.9 magnum to build [Re: a12rag] #1652093
07/28/14 03:54 PM
07/28/14 03:54 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I would use a late model LA block or Magnum for the next build to be able to use a roller cam. The LA blocks from 89 to 92 I believe had provisions for roller cams and all Magnum motors had them. A roller would give you a nicer idle with a bit more aggressive profile than a comparable flat tappet. Magnums have the added benefit of coming with a superior head.
If you don't plan on going much over 300HP I would keep the factory manifolds for the ease of working on it, ground clearance and quietness. Much over 300HP though and you start to leave a lot on the table without them.
Re: Original 360 vs 5.9 magnum to build [Re: dogdays] #1652094
07/28/14 03:57 PM
07/28/14 03:57 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Fellow board member Patrick Grossman observed similar numbers when going from an LA 360 to Magnum 318 in his Fifth Avenue. Haven't seen him post in a while though.
Re: Original 360 vs 5.9 magnum to build [Re: MarkZ] #1652095
07/28/14 04:09 PM
07/28/14 04:09 PM
a12rag Offline OP
a12rag  Offline OP
Thanks for the input - yes those are mpg for imperial gallon, not US. If I was to stroke out the 5.9 magnum, I would probably look at headers and different exhaust . . . keeping the 5.9 magnum, relatively stock would certainly be better than the LA, I was thinking . . . and of course keep the original engine tucked away . . .
The MPG concern isn't so much for what it gets, rather, how many miles I can go between fill ups, as the Duster has a small tank !!!
Re: Original 360 vs 5.9 magnum to build [Re: a12rag] #1652096
07/28/14 10:28 PM
07/28/14 10:28 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I'd be tempted to put Engine Quest Magnum heads on the original 360 block. Matching block would be in the car and you could build a real nice, efficient engine.
Sheldon
Re: Original 360 vs 5.9 magnum to build [Re: RUNCHARGER] #1652097
07/28/14 11:42 PM
07/28/14 11:42 PM
Eugene, OR
FuryBoy Offline
FuryBoy  Offline
Eugene, OR
I thought magnum blocks don't have provisions for a mech fuel pump. Is that going to be a concern? I don't like electric fuel pumps...
Re: Original 360 vs 5.9 magnum to build [Re: FuryBoy] #1652098
07/29/14 12:13 AM
07/29/14 12:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Neither the magnum block, nor the LA block have provisions for a fuel pump.
The timing covers, otoh, for an LA do.
http://www.allusedtruckparts.com/ebaypictures/TCV-245B_%281%29.jpg
You can run an LA timing cover and LA snout cam (or adapter from Hughes) on a Magnum engine and have your mechanical fuel pump.
Adapter:
http://www.hughesengines.com/Index/produ...mp;partid=22194
Don't be the exception.
Re: Original 360 vs 5.9 magnum to build [Re: RUNCHARGER] #1652099
07/29/14 12:25 AM
07/29/14 12:25 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
what is required to put magnum heads on an LA block?
Re: Original 360 vs 5.9 magnum to build [Re: can.al] #1652100
07/29/14 01:01 AM
07/29/14 01:01 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Heads, intake, pushrods, rockers, cover the requirements. You can redrill the heads to accept an LA intake, someone on Moparts had a jig that got passed around years ago just for this. You may, or may not, need to replace the lifters for oil thru the pushrods, you will have to look and see to know.
LA valve covers can work on a Magnum head, just pay attention to fitment as they are not identical. Exhaust manifolds/headers should bolt up for the most part. If you have air injection manifolds you might have an issue there.
Re: Original 360 vs 5.9 magnum to build [Re: can.al] #1652101
07/29/14 01:02 AM
07/29/14 01:02 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
http://www.moparts.org/Tech/Archive/smallblock/7.html
Re: Original 360 vs 5.9 magnum to build [Re: Supercuda] #2446899
02/05/18 03:40 PM
02/05/18 03:40 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Incorrect, the LA TBI motors did have a long snout cam with the pump eccentric with a block off plate. This changed on some 318s so you have to check before you buy - later cams used a spacer instead of the eccentric (can just swap out) or went to a cam without the provision. AFAIK the 360s all came with the long snout cam and eccentric up until phase out for the magnums.
Re: Original 360 vs 5.9 magnum to build [Re: a12rag] #2446934
02/05/18 04:39 PM
02/05/18 04:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ah, the old Moparts illiteracy program. Let me clarify for you.
As Foghorn Leghorn would say, pay attention son, I say pay attention.
Someone in the thread claimed the magnum block had no provisions for a fuel pump. No [censored] sherlock, none of them do, that's not where the fuel pump mounts.
Re: Original 360 vs 5.9 magnum to build [Re: Supercuda] #2446938
02/05/18 04:50 PM
02/05/18 04:50 PM
dogdays Offline
dogdays  Offline
Count on Montclaire to resurrect a 3 1/2 year old post to give a wrong answer!
R.
Re: Original 360 vs 5.9 magnum to build [Re: a12rag] #2446953
02/05/18 05:25 PM
02/05/18 05:25 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
LA TBI does indeed have provisions for a fuel pump. Eccentric on the cam and a bolt-on block off plate. Not that the provision is in the block anyway, it's in the timing cover; casting #3769996, the same one used from 1979 to 1990 and the end of the 360 TBI motors. It really is as simple as pulling the block-off plate and installing a mechanical pump.
Your phrasing is misleading - you are trying to score points on a technicality because FuryBoy used the word block instead of engine. Please use words instead of obscure abbreviations like otoh. There is already enough misinformation/confusion out there on the last of the LAs.
Re: Original 360 vs 5.9 magnum to build [Re: dogdays] #2446962
02/05/18 05:45 PM
02/05/18 05:45 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
R.
Who are you again?
Re: Original 360 vs 5.9 magnum to build [Re: a12rag] #2447199
02/06/18 12:38 AM
02/06/18 12:38 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
my 88 318 tbi has been converted to carb and mechanical fuel pump..I removed the blocking plate and installed a pump...
Tony
70 AARCuda Vitamin C
