Before using an electric fan
if really required.....
U better upgrade the entire electrical system, starting with the alternator, voltage regulator and bulkhead connections...
Depending upon what year Mopar, many OE alternators were rated @ < 50 Amps.. An electric fan system can easily draw up to 50/60 Amps leaving no reserve capacity for headlites, stereo, subwoofer, MSD box, fuel pump and/or other accessories..
What many guys don't grasp is that the electrical system has to be thought thoroughly through from start to finish..
For example..
Adding relays for headlites is really only part of the job..
If the rest of the electrical system is not gone through, after 35-45 years the Mopar OE connectors, sockets, grounds.
Need to be taken apart..
Kleened & coated with dialectric grease and replaced if necessary.
Just my $0.03...
