Found a couple trucks but need info on swaping parts. #1651614
07/27/14 04:44 PM
07/27/14 04:44 PM
NH
torredcuda Offline OP
NH
Guy has a few old trucks for sale and I may try and make a good one out of a combo of parts but need to know what will work. One is a `74 stanadard cab, 8` bed, 318, 4 spd with plow, second one is a `76 or 7 club cab, 6 cyl with plow. I`d like to have the club cab with a v8 so trying to decide if it`s easier to swap cabs or swap drivetrains. Are the frames/ mounts the same for standard and club cabs? What would it take to swap a the 318 to the /6 frame or a big block to either the /6 or 318 truck?
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651615
07/27/14 04:54 PM
07/27/14 04:54 PM
Lehigh Acres, Florida
rickstershemi Offline
Cool Find....How bads the body on the 74...????
Pictures Please.
Can't help you on the body swap, but someone here should chime in shortly
Used to live in Raymond Cowhampshire
Rickster
Re: Found a couple trucks but need info on swaping parts. [Re: rickstershemi] #1651616
07/27/14 05:00 PM
07/27/14 05:00 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Swapping drivetrains is do-able. The wheelbases and frame drops are different for a Clubcab.
Sheldon
Re: Found a couple trucks but need info on swaping parts. [Re: RUNCHARGER] #1651617
07/27/14 06:18 PM
07/27/14 06:18 PM
NH
NH
Sheldon
That`s what I was wondering.
The `74`s bed is toast, fenders junk, cab rusty but salvageable.
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651618
07/27/14 06:20 PM
07/27/14 06:20 PM
NH
NH
`74
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651619
07/27/14 06:22 PM
07/27/14 06:22 PM
NH
NH
another
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651620
07/27/14 08:26 PM
07/27/14 08:26 PM
Damn that 74 is toast....not surprised being from NH.
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651621
07/27/14 08:29 PM
07/27/14 08:29 PM
I'd have to pass
Re: Found a couple trucks but need info on swaping parts. [Re: rickstershemi] #1651622
07/27/14 09:41 PM
07/27/14 09:41 PM
NH
NH
I`m waiting on pics of the clubcab. I`m thinking using the clubcab chassis which should have disc brakes and swapping in the 318/4spd and transfer case (divorced NP205?) from the `74. I`ll also be getting a complete Meyers plow setup for it. It`ll be somewhat of a project but I think doable? Any problems with this idea?
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651623
07/27/14 09:59 PM
07/27/14 09:59 PM
RUNCHARGER Offline
RUNCHARGER  Offline
That rust brown singlecab looks like a fulltime 4WD to me. But at least all the parts for the V8 swap would be there. You would also have a spare frontend and NP203. Full timer is great for a plow truck.
Sheldon
Re: Found a couple trucks but need info on swaping parts. [Re: RUNCHARGER] #1651624
07/27/14 10:17 PM
07/27/14 10:17 PM
NH
NH
Owner called it a `75 but tag says 8/74 so it would still be a 1974 model.
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651625
07/27/14 10:42 PM
07/27/14 10:42 PM
5thAve Offline
5thAve  Offline
What's the VIN say? Strange how so many people don't know what year of vehicles they have or are buying.
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651626
07/27/14 11:18 PM
07/27/14 11:18 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Those are 4.5 bolt circle wheels with no front hubs on it.
Sheldon
Re: Found a couple trucks but need info on swaping parts. [Re: RUNCHARGER] #1651627
07/28/14 11:08 AM
07/28/14 11:08 AM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
Sheldon
full time truck
Re: Found a couple trucks but need info on swaping parts. [Re: RODHALL] #1651628
07/28/14 11:17 AM
07/28/14 11:17 AM
NH
NH
I`m just learning about these trucks so any help identifying stuff is appreciated!
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651629
07/28/14 11:51 AM
07/28/14 11:51 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
8/74 is the first month for 1975 models.
1975 went to full time 4wd and from 5.5" to 4.5" lug pattern.
1974 was the last of the 8.75 rears, 1975 will have 9.25 or maybe a 8.25 rear.
Re: Found a couple trucks but need info on swaping parts. [Re: B5 Bee] #1651630
07/29/14 12:34 AM
07/29/14 12:34 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
And get under the truck and check the condition of the frame and crossmembers before you lay down your hard earned money.
They love to rust through near the gas tank, and where the crossmembers attach to the side rails, especially towards the rear of the truck, and where the spring brackets are riveted to the frame rails (both ends of all 4 springs). Rusted frame pieces are hard to fix and expensive, money is well spent on a frame that is in the best condition possible. I know because this is the kind of work I do. Gene
Re: Found a couple trucks but need info on swaping parts. [Re: poorboy] #1651631
07/29/14 11:14 AM
07/29/14 11:14 AM
NH
NH
Good advice but I do bodywork, have a good welder and work in a sheet metal shop so fixing rust is not a problem.
Re: Found a couple trucks but need info on swaping parts. [Re: rickstershemi] #1651632
08/03/14 09:40 PM
08/03/14 09:40 PM
NH
NH
Rickster
Lived in Raymond for almost 20 years, just moved a town away to Epping a couple yaers ago.
Picked up the `75 today, going to be a parts truck.
Re: Found a couple trucks but need info on swaping parts. [Re: torredcuda] #1651633
08/03/14 09:45 PM
08/03/14 09:45 PM
NH
NH
