Are these the date codes? #1651601
07/27/14 04:21 PM
07/27/14 04:21 PM
USA
b54406barrel Offline OP
USA
Cleaning out a storage building. These are 14x6 wheels and they have these dates on each side of the stem hole- '11 02', 11 02', '11 28' and '9 01'. I can't see why it would matter but someone will inevitably ask, "what year are they?" Thanks. Oh, they are 4-1/2".
Re: Are these the date codes? [Re: b54406barrel] #1651602
07/27/14 04:37 PM
07/27/14 04:37 PM
MD
floyd Online content
floyd  Online Content
MD
Taken from a Moparts post years ago. I'm not sure who to thank for the pic. Month and day on either side of the valve stem hole. You need the smaller (and harder to read) plant and year stamp to figure out what year. Some of the same info is stamped on the part of the wheel inside the tire bead so look there if the tires are off.
Re: Are these the date codes? [Re: floyd] #1651603
07/27/14 04:52 PM
07/27/14 04:52 PM
USA
USA
Thank you! I know at least 2 had 2944252 on them but I didn't look at that number on the other 2. I figured that was just a part number. I'll look again & thanks.
Re: Are these the date codes? [Re: b54406barrel] #1651604
07/27/14 08:58 PM
07/27/14 08:58 PM
USA
USA
Got the area cleaned and all 4 rims are 'MI' or 'M1'. Below that are '0' on 3 of them that are pretty legible but, the 4th rim could be a 9. It's pretty poorly stamped.
Re: Are these the date codes? [Re: b54406barrel] #1651605
07/27/14 09:04 PM
07/27/14 09:04 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
that all makes sense: M1 = Motor Wheel Corp plant #1 Lansing, MI
11/02/70
11/02/70
11/28/70
9/01/70 ..... one of which might be 1969, but they are 14x5.5" wide
Re: Are these the date codes? [Re: 6bblgt] #1651606
07/27/14 09:18 PM
07/27/14 09:18 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What sucks is that they are just about exactly one month too late for what I am looking for
Re: Are these the date codes? [Re: 6bblgt] #1651607
07/27/14 10:21 PM
07/27/14 10:21 PM
USA
USA
11/02/70
11/02/70
11/28/70
Just a guess on the width, never measured. OK, good to know. For someone.
Thanks!
Sorry, Scott!
