How do I remove these knobs? Are they available?
#1651497
07/27/14 09:38 AM
07/27/14 09:38 AM
Posts: 19,954 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
71-74 B-body HVAC chrome plastic knobs. How are they removed without breakage? Are they reproduced?
Earning every penny of that moderator paycheck.
DBAP
Re: How do I remove these knobs? Are they available?
[Re: not_a_charger]
#1651498
07/27/14 10:02 AM
07/27/14 10:02 AM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
Not real scientific here but it does work. Smooth jaw needle nose pliers that won't leave a mark on the steel, grab about 1/8" from the plastic knobs. 1/4" screwdriver gently twisting / prying off alternating top to bottom. Patience and be gentle - they'll walk right off. I don't know of anyone reproducing them but it's been almost 15 years since I did a '73 Charger and swapped out controls and back then I had good spares.
Old, tired, and sometimes broke down. Me, not my car...
[Re: terzmo]
#1651500
07/27/14 10:39 AM
07/27/14 10:39 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
on some there was a small allen screw on the underside...if not...yank them off as they are pressure mounted...(best term I could come up with)
if no set screw then soak them down in WD-40 first then YANK.....
[Re: not_a_charger]
#1651505
08/01/14 11:46 PM
08/01/14 11:46 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
Those look darn close to the Abody ones and those have a small Allen head screw on the under side...but you probably looked under already?
Still looking for LM29H1B415501, '71 Demon 340
[Re: not_a_charger]
#1651508
08/02/14 01:55 PM
08/02/14 01:55 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
I did. These do not have a set screw.
no screws= pulling them off....tiny wiggle at first....then.....pull!!
