Re: 70 runner organsol hood stripes......
[Re: 469runner]
#1651209
07/27/14 05:20 PM
07/27/14 05:20 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I use a black epoxy, then a double coat... comes out very smooth this way if you do it in the right conditions and the right laquer thinner.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Roadrunner440-6]
#1651211
07/28/14 01:26 PM
07/28/14 01:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Just thinking out loud......do you suppose I might be able to get away with.....putting down a used set of decals and then spraying the stripes lightly around and over the decals. After the stripes have dried...then removing and replacing with new decals. Just thinking......
Not something I'd do,...but if I did, I'd use the a pair of the same decals (mfg'd) for "masking" as the ones that replace the painted decals, as some mfg's trimming/die cutting of decals is shaped differently, plus I'd put down a black base before "masking" with the decal, because if the decal "shrinks" over time, body color, or whatever base your using might show around the edges?...
