70 runner organsol hood stripes...... #1651205
07/26/14 04:04 AM
07/26/14 04:04 AM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
I'm ready to paint my stripes on my hood of my 70 runner with organsol black. My question is ...when applying the 440+6 decal over the black...what will keep the sticker on. As rough as organasol is...did the factory have a secret or did the stickers just not stick well?-----any help will be greatly appreciated. Thanks
Re: 70 runner organsol hood stripes...... [Re: Roadrunner440-6] #1651206
07/27/14 01:32 AM
07/27/14 01:32 AM
NO ONE KNOWS????????? My information shows that the stripes were oraganasol. Obviously the 440-6 stickers didn't last too long on this unsmooth surface. Did people just replace these stickers every couple of years or was there glue added to assure that the stickers stayed on or what?
Re: 70 runner organsol hood stripes...... [Re: Roadrunner440-6] #1651207
07/27/14 12:13 PM
07/27/14 12:13 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If you intend to spray down that 40 grit organsol finish on a 70 RR...it's not correct
The factory sprayed Ditzler DDL-9355 "fine grained" Acrylic Lacquer Organsol
Re: 70 runner organsol hood stripes...... [Re: DAYCLONA] #1651208
07/27/14 01:23 PM
07/27/14 01:23 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
DDL-9355 hasn't been available for years as far as I know. The closest I found was from Roger Gibson Auto Restoration supplies. Yes, it is a little rougher than the original, but just lay down very wet. As for the stickers I did sand slightly where they lay just to give some "tooth" and smooth the grain some. No problems in several years now.
Re: 70 runner organsol hood stripes...... [Re: 469runner] #1651209
07/27/14 05:20 PM
07/27/14 05:20 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use a black epoxy, then a double coat... comes out very smooth this way if you do it in the right conditions and the right laquer thinner.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 70 runner organsol hood stripes...... [Re: Silver70] #1651210
07/28/14 12:46 PM
07/28/14 12:46 PM
Just thinking out loud......do you suppose I might be able to get away with.....putting down a used set of decals and then spraying the stripes lightly around and over the decals. After the stripes have dried...then removing and replacing with new decals. Just thinking......
Re: 70 runner organsol hood stripes...... [Re: Roadrunner440-6] #1651211
07/28/14 01:26 PM
07/28/14 01:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Not something I'd do,...but if I did, I'd use the a pair of the same decals (mfg'd) for "masking" as the ones that replace the painted decals, as some mfg's trimming/die cutting of decals is shaped differently, plus I'd put down a black base before "masking" with the decal, because if the decal "shrinks" over time, body color, or whatever base your using might show around the edges?...
Re: 70 runner organsol hood stripes...... [Re: DAYCLONA] #1651212
07/28/14 05:16 PM
07/28/14 05:16 PM
If I were to do this...I would go with a black base. I think you've got a great idea with masking the new decals. That makes sense.-----That's why i keep returning to Mopart's....You guys give me great ideas and advice! Thanks
