68 gtx fuel line? #1651062
07/25/14 07:55 PM
07/25/14 07:55 PM
68gtx Offline OP
68gtx  Offline OP
In the process of restoring my 68 gtx. 440 4 speed. Can anyone tell me if this car should have a fuel return line? And how the vent line runs. Thanks Larry J
Re: 68 gtx fuel line? [Re: 68gtx] #1651063
07/25/14 09:27 PM
07/25/14 09:27 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Yes it should have a return line. It runs from the vapor separator at the fuel pump and follows the main fuel line back to the sending unit. Main line is 3/8" return line is 1/4"
Re: 68 gtx fuel line? [Re: wesgtx440] #1651064
07/25/14 11:09 PM
07/25/14 11:09 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
.....Exactly like my '68 is.
Re: 68 gtx fuel line? [Re: wesgtx440] #1651065
07/25/14 11:10 PM
07/25/14 11:10 PM
ga
ringo440 Offline
ringo440  Offline
ga
440 cars came with 5/16 lines 1/4 returns HEMI 3/8 main 1/4 returns
Re: 68 gtx fuel line? [Re: wesgtx440] #1651066
07/25/14 11:12 PM
07/25/14 11:12 PM
68gtx Offline OP
68gtx  Offline OP
I could be wrong but it looks like its 5/16th. I did find part of the 1/4 line plugged off. . Does the 2 nipples on the tank just loop into the trunk? Is it a closed vent or open to atmosphere? Thanks for the reply.
Re: 68 gtx fuel line? [Re: 68gtx] #1651067
07/25/14 11:21 PM
07/25/14 11:21 PM
ga
ringo440 Offline
ringo440  Offline
ga
one is a vent that goes into trunk and back out the the other is a return. your sending unit should be 3/8 the 5/16 hose is force over it.
Re: 68 gtx fuel line? [Re: ringo440] #1651068
07/25/14 11:26 PM
07/25/14 11:26 PM
68gtx Offline OP
68gtx  Offline OP
3/8 inlet 5/16th main line 1/4 return. Does it matter which nipple I use for the return? Thanks Larry J
Re: 68 gtx fuel line? [Re: 68gtx] #1651069
07/25/14 11:33 PM
07/25/14 11:33 PM
ga
ringo440 Offline
ringo440  Offline
ga
I am sorry tank ports are both vents go to right stuff detailing web site . they have everything you need. return line on sending unit
Re: 68 gtx fuel line? [Re: ringo440] #1651070
07/25/14 11:35 PM
07/25/14 11:35 PM
68gtx Offline OP
68gtx  Offline OP
Ok Thanks.
Re: 68 gtx fuel line? [Re: 68gtx] #1651071
07/26/14 10:23 AM
07/26/14 10:23 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Hopefully a picture can help - fuel line and return go into the sender unit. The two vent lines are up in the corner. One going up into the trunk and back out again and the other just a short piece.
Re: 68 gtx fuel line? [Re: 68jim] #1651072
07/26/14 10:46 AM
07/26/14 10:46 AM
68gtx Offline OP
68gtx  Offline OP
Best place to buy those lines? Thanks for pic.
