back window molding clip question on b body #1650611
07/24/14 10:20 PM
07/24/14 10:20 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
How tight should the moulding clips be on a 68-69 b body. how hard should the moulding go on ? At the mopar meet this year at maple grove dragway i did see a rear window come out while a car was going down the strip . Dont want that but it seems the trim fits tight!
Re: back window molding clip question on b body [Re: 3wracing] #1650612
07/25/14 12:41 AM
07/25/14 12:41 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The trim doesn't hold the glass in, the seal does - the trim is just for show! The clips should be tight. Make sure you have the CORRECT clips and I believe the rear uses two different clips - one type for the lower trim and another for the rest.
Re: back window molding clip question on b body [Re: Stanton] #1650613
07/25/14 02:33 AM
07/25/14 02:33 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I'm going to throw this at you.
When I did my '68 GTX, I got clip kits for the front and rear windows. The front kit was great....the moulding snapped on like a piece of cake.
Now...the back window.....
The clips were SO tight on the body that I was beginning to mark up the paint trying to install the mouldings. I ended up taking most of the clips off and slightly tweeking them so that there was a bit of a gap between the face of the clip and the body. After a couple of "tweeks", the mouldings finally snapped on like they should.
I can't remember where I purchased the clips from, but I know it was from one of the sponsors on this board.
Basically just saying that you'd better check the tightness before you commit yourself to basically having to POUND the chrome on.
Re: back window molding clip question on b body [Re: superwrench] #1650614
07/25/14 09:12 AM
07/25/14 09:12 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
I agree with the previous post. Clips hold on the trim, adhesive keeps the window in. I just did this on my Bee. Most auto shops have the ribbon seal available. I bought mine from Car Quest. See attached picture.
The clips are available from Mega Parts. My trim fit perfect with the set they sold me.
http://www.megapartsusa.com/proddetail.asp?prod=MP-WMC405268&cat=316
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: back window molding clip question on b body [Re: Big D A12] #1650615
07/25/14 04:17 PM
07/25/14 04:17 PM
Canada
rodroc Offline
rodroc  Offline
Canada
Thanks for the advice
Re: back window molding clip question on b body [Re: rodroc] #1650616
07/25/14 07:03 PM
07/25/14 07:03 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
thanks guys for the imfo. Superwrench just what i needed to hear i figured that was my next plan of attack. does NYONE HAVE A PROCEDURE FOR LOCKING IN THE FRONT SEAL?
Re: back window molding clip question on b body [Re: 3wracing] #1650617
07/25/14 07:57 PM
07/25/14 07:57 PM
superwrench Offline
superwrench  Offline
Yeh...it wasn't actually what I needed to happen either. They were REALLY tight against the sheet metal. You can't just loosen the screw either. I tweeked the clip where the screw goes thru and I think that I used a real thin plastic washer behind the clip on some so that they were all evenly gapped.
The chrome then snapped on without too much pressure like it should. There was NO WAY it was going on before that.
